front drum bolt pattern question
Old Apr 19, 2019 | 08:13 PM
BayStYat's Avatar
BayStYat
Is there any company that make front drums with different bolt patterns? I would like to run 1990 mustang wheels.
thanks
Old Apr 20, 2019 | 08:27 AM
kenny nunez's Avatar
kenny nunez
Bolt pattern
YAT, The best thing you can do is to measure the back space of the wheel you want to use and order the spacer adapter that will set the wheel properly.
I have 1.5 spacer adapters on the rear of my truck which is working out with no problems. The CV clip that I have did not need any and I have no tire- fender clearance issues.
Old Apr 22, 2019 | 08:04 AM
Freightrain's Avatar
Freightrain
I know for a fact, the hub diameter is too large for car rims. 25 yrs ago, I remachined mine for 5" bolt circle because I couldn't get it down to 4 1/2" because of the large bearings in the hubs.
Using spacers would work, as you need to get the backspacing way out for a late model rim anyway.
Willywat
Mar 15, 2010 12:47 PM
koechig
Jun 30, 2008 06:21 PM
FLUSHED UP
Apr 11, 2007 08:02 AM
Matt66
18
May 20, 2006 10:16 AM
55forder
13
Feb 20, 2004 09:48 PM
