Service Advanctrac message
Old Apr 19, 2019 | 05:24 AM
martinec93's Avatar
martinec93
I was pulling into work this morning and all of a sudden a message appears on dash and says service advancetrac. Was wondering what this means and how to fix the issue? and is it ok to drive with light on?
Old Apr 19, 2019 | 06:01 AM
seville009's Avatar
seville009
My wife’s 2013 Taurus did that early on. I never did anything with it. Message disappeared and never came back. Never had any issues. If you don’t notice anything odd, I wouldn’t worry about it. Can always check for codes, of course.
Old Apr 19, 2019 | 11:13 AM
displacement4me's Avatar
displacement4me
The single advancetrac light is likely from a wheel speed sensor for ABS and advancetrac functions, and can be read with the right code reader. It’s safe to drive, but while that light is active, features like ABS, traction control, and advancetrac are automatically disabled.
Old Apr 22, 2019 | 05:54 AM
Superdave71's Avatar
Superdave71
Stock truck or deleted? If stock it is as simple as displacement says, if deleted and your exhaust sensor connectors weren’t properly handled there could be a sensor network issue.
Old Apr 22, 2019 | 06:40 AM
martinec93's Avatar
martinec93
Truck is stock for right now. It only does it when breaking hard while turning right. Almost sounds like tire is rubbing, but has stock size tires.
Old Apr 22, 2019 | 06:51 AM
kper05's Avatar
kper05
Speed sensor has my vote but you need to retrieve the DTCs to be sure.
Old Apr 22, 2019 | 08:20 AM
Watsy's Avatar
Watsy
This warning would come up on my 2012 F150 when I steered fully to one side. It ended up being the steering positioning sensor in the rack and pinion. The downside is had to replace the complete rack as the sensors are built in and not serviceable.
I believe its in the steering column on the superdutys which would be somewhat cheaper to fix.
Just a thought.. Cheers
Old Apr 22, 2019 | 08:36 AM
displacement4me
That sound similar to a tire rubbing is likely the ABS stepping in to act on the faulty readings it’s receiving for a wheel speed sensor. Buy/borrow an OBD-II reader capable of reading ABS and it will tell you which sensor. Sensors are a fairly easy job to replace as long as you’re capable of getting the caliper and rotor off if it’s a sensor on the front.
Old Apr 25, 2019 | 02:37 PM
Slightly Tweaked's Avatar
Slightly Tweaked
Same thing happened with mine today, I'm stopping it off at dealership Monday since it's under warranty, 8200 miles. Service manager grinned and shook his head, said it's very common issue and could be any number of things to cause it. Hardest part is locating which sensor isn't communicating with network.
Old Apr 29, 2019 | 07:05 AM
martinec93's Avatar
martinec93
Did you ever find out what the problem was with your truck ?
Bigb6.0
Nov 29, 2017 09:58 PM
kcraptor82
1983 - 2012 Ranger & B-Series
Aug 29, 2017 08:57 PM
mdt6363
1997 - 2003 F150
Jan 18, 2016 05:32 PM
cliffordredfx4
Aug 25, 2013 12:56 PM
ChevmaninaFord
1997 - 2003 F150
Dec 14, 2005 11:05 AM
