Bumping in front end
Old Apr 20, 2019 | 08:43 PM
brinson's Avatar
brinson
4wd High
2015 f450 4x4 with 40k miles. I have a slight bumping in the front when traveling slowly on gravel or bumpy roads. I can feel it slightly in the steering and can hear it. Truck drives fine. I changed all shocks to bilsteins with no change. Can steering stabilizer cause this? Truck is not lifted and has stock size tires.
Old Apr 20, 2019 | 08:53 PM
jav_eee's Avatar
jav_eee
Your best bet is to get underneath it, grab each component and give it a good shake.
Also, do you have a tow hitch in the receiver?
Old Apr 20, 2019 | 08:55 PM
UP_There's Avatar
UP_There
It drives fine? That sounds like possibly the bearings are shot, or even ball-joints are done for. I would guess bearings first though, since it drives fine.
Old Apr 20, 2019 | 08:57 PM
brinson's Avatar
brinson
4wd High
I have tried to shake the components in the front end with no luck but, I will get a bar and try again. I do not have a draw bar in the hitch. Thanks
Old Apr 20, 2019 | 08:59 PM
brinson's Avatar
brinson
4wd High
Drives great. It's really light but the noise appeared pretty quickly. From no front end noise to the bumping.
Old Apr 21, 2019 | 04:35 AM
2011350diesel's Avatar
2011350diesel
Had A new 2012 f-150 that had that suspicious sound, only when it got cold..say below 30.Was really annoying. Ended up being the steering rack.Was replaced under warranty.
You could feel it coming through the steering wheel.Had it at the dealer ship countless times. Each time they would tell me it was something different with the front end. Truck had 20,000 miles.I now have 2011 f-350, no problems, but when I was researching my f-150 I saw that the superdutys were having this same problem.
You can go to F-150 Forum and there's countless pages on this.
Old Apr 21, 2019 | 01:19 PM
brinson's Avatar
brinson
4wd High
Both front prop shafts have a lot of movement on the outer ends. Probable 1/16" when pried on. Is this normal? I tried to post a video but failed.
Old Apr 21, 2019 | 01:20 PM
brinson's Avatar
brinson
4wd High
https://www.youtube.com/watch?v=qXGT...ature=youtu.be
Old Apr 29, 2019 | 11:14 PM
cangim's Avatar
cangim
Sway bar end links/bushings maybe? Could pull one off and see if noise goes away...
Brutl_Force
Jun 11, 2019 09:33 AM
Haulinbass02
Mar 4, 2018 08:33 AM
wantahertzdonut
All Things Towing
23
Apr 10, 2014 01:10 AM
Husky44
Dec 22, 2009 02:37 PM
LAD
Dec 3, 2003 08:55 PM
