Fuel pump fuse keeps blowing
I have a wiring issue 95 f350 460 instantly will blow fuel pump fuses EVEN if the tank switch itself is unplugged and if the relay is out also. And if the switch is plugged in it will do it on either tank. So that would mean the wires under the fuse box are shorting out correct. And if that is the case how do you pull the fuse box off the metal bracket.
Which fuse is blowing, one in the middle row under the hood? When the radio capacitor on the coil of my '94 F-150 shorted out, I could hear the fuel pump run for a split second before it would blow, I think the third fuse from the driver side fender in the middle row in the fuse box under the hood. I thought I had a problem with the fuel pump system, I would have never figured it out if I had noticed the bad wire on the capacitor on the coil.
I suspect your problem may be with the ignition, but I sure could be wrong.
Check continuity on each fuel relay socket wire to ground, looking for a short.
Fuse "O" 20A ?
Some information on this thread:
https://www.ford-trucks.com/forums/1...ution-box.html
Attachment 280139
Attachment 280134
Playing devils advocate, pulling the frame harness doesnt mean its clean. You can have multiple spots with failed wiring/insulation. Pulling fuses and plugs can have you chasing your tail til the point of madness! Get a decent multimeter with a continuity function and chase down your short(s).
i just relooked at that diagram i is the one that blows but the only thing that quits when it blows is the fuel pump. So this whole time ive been looking at the wrong ****
So it sounds like you have a short to ground on the Red #361 wire or something that it feeds.
Here the wiring diagrams:
It starts out at the PCM Power relay and goes from there to all of the solenoids, relays and the PCM Computer.
Just follow the red wires in the diagrams I posted above.
yes but the fuse still blows if i disconect the engine harness from the main harness so i know thats ruled out so its either gotta be in the dash or in the engine bay harness but ive run out of leads
