Searching for a Radiator Shroud
I recently install a replacement radiator in my 1965 Ford F-250 Camper Special that is running a 352...
The old one was apparently not OEM... At least, it wasn't what came from the factory in San Jose back in the day, I was told...
The part number (433444) fits and works, but it was allegedly for some type of 4WD rig.
What I want to do now is put a shroud on it...
I've found stuff on line that "might" work, but, before I order, I thought I'd check with the forum.
I could have one made, I suppose, but I don't want to go "there" ... yet.
Notions? Ideas?
Notions? Ideas?
Check out this thread from a couple years back, think I’d like to have one myself:
https://www.ford-trucks.com/forums/1...an-shroud.html
The old one was apparently not OEM .. At least, it wasn't what came from the factory in San Jose back in the day.
There was no factory fan shroud for 1965/66's, but...
D3TZ-8146-C (replaced C8TZ-8146-K) .. Fan Shroud / Marked on upper left corner: C8TA-8146-S or D3TA-8146-DA / Reproduced by Carpenter
Original applications: 1968/76 F100/350 360/390 with standard, xtra cooling and A/C radiators.
In 1981, I bolted one of these on my 1965 F100 352, it fit like it was made for it. I've listed this info dozens of times in this forum.
This is the same shroud as listed in post #3.
