d7ta afc radiator
Old Oct 27, 2014 | 09:06 PM
f-250.4x4.390's Avatar
f-250.4x4.390
d7ta afc radiator
1977 u-hual. leaking radiator and it has no fan shroud. What are my options to cross reference this radiator to something that will bolt right in, that has fan shrouds readily available for it. Or is there a direct replacement that includes dual electric fans?
I've looked for this particular part number (d7ta afc) which is stamped into a small tag that is attached to the backside of the radiator, and havent come up with much.
Old Oct 28, 2014 | 12:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by f-250.4x4.390
1977 F350 U-Haul, leaking radiator and it has no fan shroud.
I've looked for this particular ID engineering number (D7TA-AFC) which is stamped into a small tag that is attached to the backside of the radiator, and haven't come up with much.
Not surprising...since this isn't the part number.
1973/78 F350's made exclusively for U-Haul came with the 330 2V Medium Duty FT engine and a Super Cooling Radiator (26 1/4" wide x 24 11/16" high).
This isn't the radiator that was used for this application. It was swapped from a 1973/76 F100/350 360/390 or 1977 F100/350 351M/400.
In order to get this radiator to fit properly, its flanges have been modified or the radiator support (1973/79's with round headlamps only) has been changed.
Super Cooling Radiator is higher than the standard/xtra cooling and A/C radiators, so its radiator support has a larger opening radius.
ID engineering number: D7TA-AFC = Ford part number: D6TZ-8005-D (replaced D3TZ-8005-C) .. Radiator ~ 26 1/4" wide x 19 3/4" high x 1 15/16" core thickness.
Misc: 1973/76 F100/250 2WD/4WD & F350 360/390 & 1977 F100/250 2WD/4WD & F350 351M/400 - Use with standard, xtra cooling and A/C.
D3TZ-8146-C (replaced C8TZ-8146-K) .. Fan Shroud-Use with standard, xtra cooling and A/C radiators - NOT used with Super Cooling Radiator!
Marked on upper left corner: C8TA-S or D3TA-DA / 1968/76 F100/350 360/390 / Reproduced by Carpenter.
C7TZ-8146-B .. Super Cooling Radiator Fan Shroud / Marked on upper left corner: C7TA-H or D2TA-HA or D3TA-JA / Reproduced by Carpenter.
1968/76 F100/350 360/390 / 1973/78 F350 with 330 2V M/D FT engine.
Old Oct 28, 2014 | 04:08 PM
f-250.4x4.390
I acquired today a new but fairly old parts house radiator out of a 1972 f-100 2wd. long bed that was at my parents house, the only numbers i can find on it are on a sticker that was on the top. those numbers are... MD: 433433, PWO: 0c1079, REF: c00a. and i got the fan shroud off of it and the number i can find on side of it is c8ta 814x <---- i'm pretty sure there is another number there where the x but its missing due to the way the shroud was molded. Do you think this radiator will bolt into my truck where it has been modded to accept the rad. that is in there now.
Also i didnt know for sure but i really thought this Rad. wasnt the original, I assumed that the u-haul trucks had a larger more robust rad. in them.
Old Oct 28, 2014 | 05:20 PM
NumberDummy
I acquired today a new but fairly old parts house radiator out of a 1972 f-100 2wd long bed that was at my parents house.
i got the fan shroud off of it and the number i can find on side of it is C8TA-814x <---- i'm pretty sure there is another number there where the x but its missing due to the way the shroud was molded. Do you think this radiator will bolt into my truck where it has been modded to accept the rad. that is in there now.
If the 1970 F100 came with a 360/390 and the shroud has a C8TA ID number prefix, it's marked: C8TA-8146-S
D3TZ-8146-C (replaced C8TZ-8146-K) is the part number for the fan shroud = Use with standard/xtra cooling & A/C radiators.
See post 2 for the difference between this shroud & the shroud used with the Super Cooling Radiator only (C7TZ-8146-B).
columbia1spring
Aug 12, 2017 06:49 PM
gafarmboy
Aug 25, 2016 08:54 PM
skidoorulz
Jul 5, 2016 07:17 AM
dustyroad
Aug 9, 2013 06:57 PM
68cabby
Feb 7, 2013 05:04 PM
