ign locking cylinder replace
Old Apr 15, 2019 | 11:01 PM
dremtofford's Avatar
dremtofford
the locking cylinder for the ign on my 91 explorer moves without a key so i bought a new one and can not find the little hole to put the pin in. so oi figured i have to take the shroud off the steering column. i got the two screws out but i have a plastic collar right below the steering wheel. do i have to take the steering wheel off to get the collar off?
Old Apr 16, 2019 | 10:16 AM
shorod's Avatar
shorod
I've not removed the shroud from a1991, but I doubt the steering wheel needs to be removed. Maybe you need to tilt the column a bit differently to free up the lower shroud? Also, sometimes there are little plastic tabs that snap over points to retain the shroud and a bit of twisting or applying pressure in the right area will release the tabs.
-Rod
Old Apr 16, 2019 | 05:46 PM
dremtofford
i will tinker with it a bit more tomorrow i tried for a half hour yesterday and i am trying to be careful so i don't break or scratch it up.
Ruckin69
Dec 21, 2017 08:35 PM
bradsblue89
Aug 25, 2014 12:14 PM
MThrasher16
May 4, 2013 08:57 PM
mhg605
Dec 11, 2011 05:29 PM
bigb609
Oct 25, 2011 07:32 PM
