1991 Ford F150 stalls intermittently
Help Help Help Help,
I have a 1991 Ford F150 2 door pickup truck, 4.9L with Over Drive. Over the last two weeks, the engine would stall intermittently when I hit the gas peddle after stopping (i.e. at a red light). The check engine light flickers but would go away immediately. It restarts and then runs fine. The idle is smoothe and I feel no loss of power.
I took it to a near by service station. They ran a computer check for codes:
Several codes showed up:
172 - EGO not switching, lean EXH-Bank 1
181 - Cruise rich limit, Bank 1 still open
327 - EGR (EVP/PFE/DPFE) signal too low
328 - EGR (EVP) voltage below closed limit
332 - EGR valve not opening (EVP/PFE/DPFE)
556 - Fuel Pump relay primary CKT
634 - Manul Lever position out of range
626 - Coast clutch selonoid ?
KOER
213 Sout cKT open
What does all this mean? Where should I start given the symtoms I've stated above? The technician was clueless and I do not want to play the quessing game of change this, change that until something works.
Please, some one help me.
P.S. I've just recently changed the plugs, wires and air filter and had an oil change.
Please email me at deleted by moderator to stop spam
KOER
213 Sout cKT open
DBGrif91
09-09-2013 05:21 PM
fordman16b
03-11-2007 02:34 PM
