What head gasket and head stud??
[QUOTE=TooManyToys.;18600566]I'm using FelPro because I need the extra thickness. And I think it's a good gasket. The Motorcraft in my motor I think did a remarkable job. Next, you have to decide cost and that's a big differential.[/QUOTE
Cost is Definitely a big concern. However this is not a place I want to skimp either. ]
You can figure that out by measuring the width of the core plugs around the head. The original designs of the head, I believe 4 used 28mm plugs. The redesign “commonized” heads introduced mid 2006 both on the motors and as the service replacements use 32mm plugs. That wasn’t a clue I had when I started this and bought the 18mm gaskets when I needed the 20mm.
Felpro is what I'm using since my heads have been machined and I'm not using o-ringed heads.
If you planned on using o-ringed heads, use the Motorcraft had gaskets.
Consider the Felpro exhaust manifold gaskets as well. These trucks never came with them and they do an excellent job of preventing power robbing leaks.
Reidicus
09-12-2006 07:46 PM
nizzl01svt
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
02-03-2005 06:21 PM
