Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
OBDII Splitter with Forscan and Banks IQ Display/Tuner
Old 04-15-2019, 10:21 AM
2004 F450
2004 F450 is offline
2004 F450 is starting off with a positive reputation.
I bought my early 04 4X4 crew cab W/B&W Hauler bed two years ago with 72,000 miles on it. Original owner went hole hog with Banks everything installed. My question is can a OBD II splitter be used with Forscan and the Banks IQ display both reading at the sometime?
The 6.0 has been studded and Bulletproof EGR cooler installed, all work was done by FORD.
Thanks,
Chuck
Old 04-15-2019, 07:57 PM
ToolmakerRob's Avatar
ToolmakerRob
ToolmakerRob is offline
ToolmakerRob is gaining momentum as a positive member of FTE.
You may have to just buy the splitter and try it. I believe that some have had success but I tried to do it with my Edge tuner to use it for the EGT monitor and have my TorquePro on the other half and the two units fought like little kids in the back seat of a car.
Please let us know if you are successful with this.
Rob
Old 04-15-2019, 11:38 PM
2004 F450
Thanks, yes I will update if it works or not. I'm just running the Banks IQ in stock tune mostly using it to monitor engine and Trans. Just starting to setup Forscan first thing I see a problem with I think is the BARO KOEO is reading 14.2. Also when I picked Ford boost PID it shows MAP on the gauge. So I have two MAP gauges that both use the same PID address, havent looked close at the formula yet.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
