1988 351W distributor replacement
I've had the TFI fail a couple of times - very scary when you lose power steering and brakes at 60mph! Considering relocating the TFI, but might take it a step further if I can find an aftermarket distributor that functions without the TFI module. Any suggestions would be helpful. Thanks, Dan
A mechanic replaced the TFI, don't know the brand but I know it didn't come from a Ford dealership. I was under the impression that some of the MSD distributors had eliminated the TFI but if that's not the case I'll definitely remount the TFI on one of the fender walls. Is there a specific brand of TFI that you recommend? Thanks, Dan
Thanks. I'll try and figure out which TFI was installed. If I can't eliminate the TFI I'll probably keep the original distributor as it has given me no problems.
Found a remote kit online (McCully Racing Motors- We have exactly what your over-heated TFI Module Needs!) - looks like it will save a trip to the junkyard.
tempest411
03-26-2014 06:12 PM
Gibby55
05-24-2011 03:41 PM
dcassidy
09-28-2009 09:12 PM
