Bds track bar drop mount
Old Apr 12, 2019 | 06:40 AM
KIDkiser's Avatar
KIDkiser
Bds says to torque the bar to 405 pounds,while I see ready lift says to torque to 250 pounds,which is right?cause that’s a big difference.
Old Apr 12, 2019 | 09:57 AM
Busa 1 Dave's Avatar
Busa 1 Dave
Well this is a easy one. Call BDS and ask them it is their product, or Call Ready Lift and ask them. I use the BDS product which is what my installers prefers to use. There is most likely a reason for this---not on this truck but on a previous one (2500 Ram) had the bolts loosed a bit and it creaked/groaned. 26k on the 18 F250 and no issues so far it is still tight.
You are smart to question this and want to understand the rationale behind the install specifications involved.
Old Apr 12, 2019 | 12:51 PM
DeputyDiesel's Avatar
DeputyDiesel
Anyway to find the ford factory bracket torque specs? That would be a good starting point
Old Apr 12, 2019 | 04:46 PM
KIDkiser's Avatar
KIDkiser
Well I contacted both companies.ready lift said after extensive testing that 250 was plenty with there bracke,but if it made me feel better I could go to 405.bds kept referring me to my closest dealer,which said “we go to 405 cause that’s what the factory is”.so there you go,looks like you should just use your better judgement
Old Apr 12, 2019 | 04:58 PM
user 474747383's Avatar
user 474747383
BDS Bracket is Solid steel and the Ready lift is a Cast bracket.Maybe they don't trust 405Lbs on the ears where the the bolt goes through. Hope not
Old Apr 12, 2019 | 05:09 PM
KIDkiser's Avatar
KIDkiser
That’s what I was worried about on my bds bracket, my installer brought out a 5 foot torque wrench and went to 405 and I could just hear those ears breaking,but they didn’t.
Ian123
Oct 9, 2013 02:48 PM
F350SD
Apr 20, 2007 06:07 PM
JIMRSX
Jun 12, 2006 04:42 AM
6fan
Jan 22, 2004 07:41 PM
ECM
Feb 26, 2003 09:58 AM
