Sponsored by: Real Truck
lift issues still...
Old Jan 22, 2004 | 05:50 PM
6fan's Avatar
6fan
Trailering
Im the guy with the clunk... I was wondering if I need to replace the trac bar b/c the bushings might be bad and also the stock one is not tough enough for a 6in. lift. I called the local fab shop and he said he couldnt make one b/c of geometry issues. So he recommended that i buy one from skyjacker which would come out to an additional 480 bucks cause I would need different brackets as well. Does anybody still have their stock trac bar with a 6in. lift??? I have a superlift can I use skyjacker parts also??? This lift project is driving me crazy... although the truck looks good... Please help!!!
Old Jan 22, 2004 | 05:57 PM
Yeti's Avatar
Yeti
Yes, you can use your stock track bar with a 6" lift. But it's not a bad idea to use an aftermarket adjustable bar.
Why would you need different brackets for an adjustablee bar?
You can mix and match parts with no problem, I have SL , Fabtech and sky jacker parts.
Remind me again, you checked out the track bar bracket? those bolts need to have some tourqe on them, I replaced all the hardware on mine and used some big air to get them tight.
I think JetJock even welded his .
Sway bar links are good?
Old Jan 22, 2004 | 06:09 PM
6fan's Avatar
6fan
Trailering
Im going to call back now about the 2 brackets Ill have an answer soon... Thanks for the comments...
Old Jan 22, 2004 | 06:17 PM
DCSpecial's Avatar
DCSpecial
I believe with the Skyjacker adj. trac bar you also have to use a bracket on the lower mount if I remember correctly (could be wrong). Probably trying to sell the upper bracket as well..........although I don' think it would be needed if you already have a drop trac bar bracket with your 6" lift.
FWIW, there are other options for adj. trac bars.
Hope this helps.
Old Jan 22, 2004 | 06:18 PM
Yeti's Avatar
Yeti
I know earlier trucks had a much thicker bar, but I dontr remember what year they switched. I remember some one here hitting a good size hole, and bending the track bar.
But I wouldn't think the bushings would be bad. possible I guess.
Does it seem like the passenger side of your truck is lower than the drivers side?
6fan's Avatar
6fan
Trailering
ok the local fab shop said the brackets are used for repositioning the bar and reinforcement however he said that if I wanted to just go with the bar and try it out I could so now I'm really confused...
Old Jan 22, 2004 | 06:20 PM
6fan's Avatar
6fan
Trailering
Hey Yeti, the truck sits level on all fours no sagging anywhere...
Old Jan 22, 2004 | 06:21 PM
DCSpecial's Avatar
DCSpecial
Were they both the Skyjacker brackets??
FWIW, if you have a clunk I'd retorque everything to spec, inspect the bushings in the sway bar links and make sure the sway bar links are installed properly first.
I believe the smaller trac bar was used in some of the '02 models............and I have seen a few of them bent.
Old Jan 22, 2004 | 06:23 PM
Yeti's Avatar
Yeti
I would think that if your bar was to short, or they sent you the wrong bracket, the bar would literally pull down the right side of the truck.
If it drives normal, Im thinking its the bracket lifting from the frame, and then "poping" back or your sway bar links are messed up.
Does it only make the clunk when turning? Usually left turns?
Old Jan 22, 2004 | 06:24 PM
6fan's Avatar
6fan
Trailering
My trac bar is 3/4in. dont know if thats the big one or small one???
Old Jan 22, 2004 | 06:25 PM
Yeti's Avatar
Yeti
Your kit should of come with a drop track bar bracket it repalces the stock bracket so you can re use the stock track bar
Thats the big one
Old Jan 22, 2004 | 06:27 PM
6fan's Avatar
6fan
Trailering
The majority of the time it does it on right turns, it does it on left too...
Old Jan 22, 2004 | 06:28 PM
Badford's Avatar
Badford
try suspension connection . com they have good prices on the bigger trac bar the small one is 3/4 the bigger is 1"
Tony
Yeti's Avatar
Yeti
Here is a pic of the kit, the bracket in the middle is the track bar bracket
6fan's Avatar
6fan
Trailering
i got a pitman arm and a trac bar bracket new leafs (4) and shocks and sway bar link brackets. No new trac bar though
