Sponsored by: Real Truck
Torque specs.
Old Feb 26, 2003 | 09:26 AM
ECM's Avatar
ECM
Question Torque specs.
Does anyone our there happen to know the torgue specs for the front axle U-bolts and the track bar bolts. I'm in the middle of a lift here at work and I left my manual at home. Any help would be appreciated, I'm pushing to get it done today.
Old Feb 26, 2003 | 09:32 AM
FortyFords's Avatar
FortyFords
Torque specs.
Hello !
Front u-bolts are 99 ft/lbs -133 Nm.
track bar to upper mounting -369 ft/lbs
" " lower is the same !
Anything else needed ?
Rich
Old Feb 26, 2003 | 09:37 AM
ECM's Avatar
ECM
Torque specs.
Thanks FortyFords, thats was just what I needed. And DANG! 369 ft/lb. I guess I need another torgue wrench.
Old Feb 26, 2003 | 09:48 AM
CO4x4SD's Avatar
CO4x4SD
Torque specs.
Forty - 369 ft. lbs. sounds pretty extreme for any light duty automotive application. I haven't found a Haynes anywhere yet, but the lift/level kit instructions for my truck indicate a torque of 110 ft. lbs for the track bar where it attaches to the track bar bracket on the frame. Specs for the front u-bolt from the lift were 120 ft. lbs.
My track bar is torqued to 110 and I used lock tight. I do 120 on the front u-bolts and 140 on the rears. Since I lifted the truck myself I have been checking the torque a few times here and there. The track bar stays tight with the lock tight, the fronts took about 2 sessions to get them to stay, and the rears took about 3 sessions to get them to settle in finally.
Old Feb 26, 2003 | 09:58 AM
FortyFords's Avatar
FortyFords
Torque specs.
Could be a miss print no dout in the Helm 02 shop manual . I don't have a lift so I wouldn't know .
I did have my glasses on though !
Rich
