Leaf Springs
Old Apr 16, 2019 | 09:02 PM
fordboy2's Avatar
fordboy2
I previously put new oem x codes in an excursion I had and would do it again. I did not feel the ride was bad and the EX actually sat like it should have from the factory in my opinion.
Old Apr 16, 2019 | 11:22 PM
Eaglescout94's Avatar
Eaglescout94
Just to give you an idea what x codes plus ranch hands looks like here’s a pic. Don’t mind the ridiculous amount of rake, planning on fixing that this summer.
Not the best pic but x codes fromATS with stock sized 265/75r16. The 285 fill out the wheel well a little more and the width looked good in my opinion when I ran them.
Old Apr 17, 2019 | 01:36 PM
brian42's Avatar
brian42
Veteran: Navy
Back in the day with OEM V-Code springs up front with 265/75-16 tires...
Not as far back with ATS "X-Code" (43-818) springs up front with 285/75-16 tires...
Old Apr 17, 2019 | 04:22 PM
SammyHou2012's Avatar
SammyHou2012
Thanks for the pics guys, that helps! Mine measures 38.5” to top of fender on front end and 40.75 on the rear. Hopefully get some time next to get it done and will post some pics.
Old Apr 17, 2019 | 05:21 PM
liquidlounge's Avatar
liquidlounge
I think that's a good plan. You already own them and you probably wouldn't get someone to pay even as much as for what new ATS springs cost. Me personally, I would rather have the Ford OEM ones. For sure you will gain a couple inches of travel.
Old Apr 17, 2019 | 09:41 PM
pirate4x4_camo's Avatar
pirate4x4_camo
If you are wanting a 2” of lift but keep the stock 430 lbs. inch spring rate then the Procomp 22210 is a good choice, also they are “on sale” right now on amazon for $96 a piece. ( don’t mind the pic, they used the wrong one,, those are rear springs )
Amazon Amazon
Old Apr 25, 2019 | 10:57 PM
SammyHou2012
Update to game plan. I'm looking at doing a lift and new tires. I've been looking at the 4.5" hanger lift from ICON so I can put 35's on the truck. Also looking at the ICON VS 2.0 shocks and dual steering stabilizer. Does any one recommend this set up or have pictures of their F250 with similar lift/tires? Or would you recommend a different lift kit/brand? I don't want anything higher than a 4-5 inch lift. I'm still wanting to put on these OEM X-Code leaf springs but not sure if that'll raise the front end to be higher than the rear after the lift is installed.
Thanks!
Old Apr 26, 2019 | 06:51 AM
fordboy2's Avatar
fordboy2
Keep in mind the hanger kit is going to be a true 4.5 inch lift. No sag Or settling with a hanger lift. Then add new x code springs your going to be well past the 4-5 inches you desire I would think.
Old Apr 26, 2019 | 09:48 PM
SammyHou2012
Wonder if 35’s would end up looking too small after that? Are there 36” tires?
Old Apr 26, 2019 | 09:54 PM
Eaglescout94
A lot of 37s measure out to 36”-36.5”. There are some that are true 37s but most seem to be under
Old Apr 30, 2019 | 12:07 PM
th67ss's Avatar
th67ss
https://www.amazon.com/Explorer-Pro-.../dp/B000CNBQ12
Would you need a drop track bar bracket or pittmen arm with these springs?
Old May 4, 2019 | 03:04 PM
C1959palmer's Avatar
C1959palmer
I'm new to posting I have only ever posted 1 other time and I cant for the life of me find how to post a new thread but hopefully someone can answer what these rear springs are off of as they were given to me.
Old May 4, 2019 | 10:38 PM
  #28
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
These springs are from a 1999 F-250 Super Duty. The particular part number seen stamped on the leaf indicates that these springs are among the lightest duty (softest, lowest spring rate) rear springs Ford offered on the F-250 in 1999.
Fawnpugsx2
Apr 29, 2019 03:28 PM
jasoncw
Apr 12, 2018 01:21 PM
Zwalters
Oct 24, 2015 02:28 AM
aldridgec
Sep 14, 2007 08:07 PM
