52 239 flywheel install
Old Apr 11, 2019 | 05:01 PM
grandaddy's52's Avatar
grandaddy's52
After 2 years working on this project, I set the motor back in the frame. I was going to put my flywheel on. Is there a certain orientation it goes on? It has the two line up pins, on the crank. It could go 180 degrees either way. Does it matter on flywheel orientation to crankshaft? Is it best to go ahead and bolt bell housing to motor or transmission to install transmission?
Old Apr 11, 2019 | 05:04 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The Flat V8's have neutral balance, the flywheel can go either way.
Old Apr 11, 2019 | 08:14 PM
grandaddy's52
Thanks Ross. I can torque it down.
yard_dawg
Sep 28, 2008 01:27 PM
junkyarddog82
Feb 12, 2008 09:53 PM
FatzFord
16
Feb 27, 2004 09:04 AM
