How bad could it be?
Old Apr 11, 2019 | 09:56 AM
Glowplugger's Avatar
Glowplugger
I'm considering adding another to the herd. The thing is, it's been used in a working environment (read *dusty*) and the interior is trashed. Assuming the price is right, miles are low, and it runs/drives, how bad is a little dust on our babies?
Edited to add, it's a "boy" truck. Not an automatic transmission.
Old Apr 11, 2019 | 11:03 AM
pirate4x4_camo's Avatar
pirate4x4_camo
It’s not the dust on the truck I would worry about it’s the dust IN the truck I would be concerned with.
what air filter is on it now and does it have any record of being serviced regularly ?
as far as how bad can it be ? Think of dust as sand paper inside your engine, it will score the cylinder walls causing oil to get past the rings, result is oil burn, blow by and loss of compression. Dust that gets in the oil also scores engine bearings causing a loss in oil pressure which of course is going to shorten the service life of the engine.
Moral of of the story, Check compression, blow by and oil pressure should tell you how good a job the PO did at keeping air filters clean and sealed and dust out of the engine
Old Apr 11, 2019 | 11:30 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
My truck had a previous life living between Texas and Louisiana. It was very dusty and needed some TLX when I bought it.
Despite having the original air box in a dusty environment, I was not put off because the air box still closed well and the compressor wheel looked like this after 2xx,000 miles.
Sharp edges and no signs of dusting.
So, to answer your question, it could be really bad, but it also could be really good as well. Pay close attention to the signs of neglect or love.
Old Apr 11, 2019 | 04:16 PM
Glowplugger
Will do guys. Thanks! I'll post up a build thread if/when I get him home.
mrkansas
1997 - 2003 F150
Mar 2, 2011 07:53 PM
Evilroot
13
Nov 21, 2010 05:44 PM
allen410
Nov 1, 2004 08:55 PM
Angus beef
Nov 12, 2003 07:06 AM
smarble
Nov 11, 2002 01:54 AM
