'89 F150 Pushing oil into air box
I'm trying to figure out exactly what's going on with this truck. Got it last week for a steal since it had a leaking valve cover seal (which I've already replaced). Has 160k on it, a brand new transmission and clutch, and runs perfectly. But for some reason the air box is filling up with oil. I replaced the PCV valve and it hasn't made a difference.
Any suggestions? The engine runs perfectly, everything is nice and smooth and I intend to make it my daily driver. But the oil stain on the driveway is getting bigger and I can't for the life of me figure out why it would be blowing oil into the air box like it is.
How could bad rings cause excessive pressure like that. i am very curious as to how you have come up w/ that? Usually bad rings is associated w/ not having good pressure in the combustion chamber, in turn you would have low power? I would do a compression/ leak down test before you think your rings are suspect..
Mario
on
Is this a 302 or 351? I have seen a few Windsors where the PCV vacuum port is plugged up with carbon, rendering the PCV valve inop. Pull the PCV valve out while it is running and stick your thumb over the end to see if you have strong vacuum there.
The air/fuel mixture will go past the rings on compression. This is called "blow-by". All engines have some, that's what the PCV (Positive Crankcase Ventilation) valve is for, to remove these gases, which are very high in HC, and burn them in the engine. A hole in the piston will cause the condition he describes, too.
I would look into still doing a compression / leak down test. Jasper also has blocks for a decent price if u discover u need a new one bro. Good luck
Look foward to see a new build
Mario
TexasGuy001
17
06-26-2009 11:25 AM
Randoo
06-19-2003 10:42 AM
