push button start warning on a diesel
Old Apr 9, 2019 | 04:12 PM
CarterKraft's Avatar
CarterKraft
Mine does that.
Changed my fuel filters last night, press button once door open no foot on brake, allow pump to cycle, repeat two more times. Hold down button door open again no foot on brake engine will start.
I don't see the problem. Why would your foot need to be on the brake to start the engine, why would that be a safety concern if it did?
edit: I have police mode enabled if it matters. I also get full accessory mode with a single press of the button door open/no brake.
Old Apr 9, 2019 | 04:17 PM
speakerfritz's Avatar
speakerfritz
Originally Posted by CarterKraft
Mine does that.
when I’m sitting inside with door closed, you can not start with out foot on the brake. There is a message prompt that says, put foot on brake to start
but with door open, I can start with no foot on brake..no message prompt.
the problem is if I pull my filters and attempt a fuel system prime with door open, truck will dry start ...I will not be able to prime my fuel system with door open...or standing outside.
so I need to have door closed to prime the system ....
now, is that the defualt...others are saying it’s a defect
be careful if yours does this....I doubt if you are priming the system if it truly does.
Old Apr 9, 2019 | 04:51 PM
landman873's Avatar
landman873
There was a guy on FB that his would do that also. He was deleted and there was something in the software that caused his to do it.
Old Apr 9, 2019 | 04:56 PM
speakerfritz
Ok, mine is stock
i guess I’ll start a gremlin list and let them check it out when I bring it in for service
Old Apr 9, 2019 | 05:44 PM
FATC1TY's Avatar
FATC1TY
My 19 does this as well.
However I think there’s a difference here.
Theres a difference between short press and holding it.
Im able to open door, lay key in seat for proximity, and if I hold down the push button start it’ll crank after a few seconds and no brake touched.
If it needs primed and I want accessory mode, you just push it and release. Similar to starting it when you have to put your foot on the brake. I have never held the button down to start anything.
Go try it simply just pushing the button once and allowing it to start up the screen and full power accessory mode. The fuel pump primes doing that as well.
Old Apr 9, 2019 | 05:49 PM
CarterKraft
I learned of this "feature" from this forums other users. I am not saying it's right or wrong but in my 19 years of super duty ownership 3 key on cycles has been enough to prime the fuel system.
How do you know yours is primed? I wait until I can't hear air through the primary, that's about 3 key cycles.
Again I don't see the rub, they allow you to start the engine from outside the truck, I appreciate it and the last thing I would do is complain 😉
Old Apr 9, 2019 | 05:50 PM
CarterKraft
Exactly, well said.
Old Apr 9, 2019 | 05:54 PM
speakerfritz
In the video I also do a closed door push to start with no brake and it does not start and I get the press brake to start banner.
with door open I do not get the banner, it just starts.
same push technique.
Old Apr 9, 2019 | 06:15 PM
CarterKraft
In the first example in the video you are HOLDING the button correct?
The button is not to be held for a normal start, merely push the button one "click" to power up and start the truck simultaneously. No need to hold the button ever unless you want to start the engine from the ground foot off the brake.
Old Apr 9, 2019 | 06:20 PM
FATC1TY's Avatar
FATC1TY
this exactly. I’m with you, our trucks start in the identical fashion. No need to hold. In his video it appears he holds the button down just long enough.
I find it working correctly. A safety function if you will, in that it requires you to hold brake and hit button, OR you have to hold the button down thru the start cycle before it’ll fire up. For the very reason many of us would start the truck and not want to climb in the damn thing.
I dont think OP has anything wrong.
Old Apr 9, 2019 | 08:18 PM
CarterKraft
When I first bought the truck I was holding the button down to start the truck and a few weeks in I realized you only have to push the button one time and it will power up the truck, time the glow plugs, engage the starter and release the starter all autonomously.
Old Apr 9, 2019 | 08:46 PM
2009kr's Avatar
2009kr
Just tested on my 2017. No brake, press the start button and you get the ACC mode (and fuel pump prime). Same test, but holding the start button down and, lo and behold, it starts after 1 - 2 seconds. Learned something new tonight.
Old Apr 9, 2019 | 09:10 PM
  #28
Mykroft77's Avatar
Mykroft77
I just tried this out on my new 2019, and it sure does work. I never long pressed on the start button anyways so this is a great thing to know about.
Old Apr 10, 2019 | 07:15 AM
  #29
BocaIvan's Avatar
BocaIvan
What we learned...
Don't hold the push start when priming the fuel system, simply press and release.
Old Apr 10, 2019 | 07:35 AM
  #30
speakerfritz
Originally Posted by BocaIvan
What we learned...
that's not the issue....with door closed the truck will not start with out brake engagement , regardless of the bottom press technique used. demonstrated in the video. key point with door closed you always get the press brake to start banner
with door open, you can start the truck with out tapping the brake using any button technique. as demonstrated in the video. key point with door open you never get the press brake to start banner
so yes, I need to put this on a gig list and have them check it...and in the mean time...keep the door closed if I want to prime the fuel system.
