Cold heater when idling
Old Apr 7, 2019 | 02:15 PM
Oilman84's Avatar
Oilman84
Hey guys..heater blows hot when running down the highway but when at idle it turns cold..any ideas?
Old Apr 7, 2019 | 02:30 PM
navistarnut's Avatar
navistarnut
Partially plugged heater core
Water pump going south
Low on coolant
Thermostat needing replaced
Old Apr 8, 2019 | 01:54 PM
Yahiko's Avatar
Yahiko
Low on coolant
That was what I was also thinking.
Old Apr 8, 2019 | 07:19 PM
KIDkiser's Avatar
KIDkiser
My 6.0 did the same thing when the headgaskets went south.are you getting any puking from the degas tank?
Old Apr 9, 2019 | 07:25 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
So did mine, that's an early sign of head gasket failure. I did all of the above and got my answer when I pulled my heads.
Old Apr 9, 2019 | 09:08 AM
ToolmakerRob's Avatar
ToolmakerRob
Perhaps you could do a coolant pressure test as well. There is plenty of info on this on the forums.
Rob
Old Apr 9, 2019 | 03:05 PM
Yahiko's Avatar
Yahiko
I think the least amount work step would be just to check the coolant level and coolant temp.
Old Apr 9, 2019 | 05:29 PM
69cj's Avatar
69cj
Simple and cheap checks are always the best way to start.
Old Apr 9, 2019 | 08:38 PM
Yahiko's Avatar
Yahiko
So true. I find that it's best to not bother the Check Book/Credit Card holder unless really needed.
wbnethery3
1997 - 2003 F150
Jan 16, 2014 02:12 PM
bballard1559948
1997 - 2003 F150
Dec 14, 2011 06:00 PM
Justin's Green Truck
1997 - 2003 F150
Mar 28, 2010 09:12 PM
smoke n tires
Dec 6, 2005 03:00 PM
bigsnag
13
Mar 22, 2004 06:38 PM
