Pressure bleeders are nice, i thought about buying one and using the old master cylinder lid to seal in the pressure. But i decided it was more than i wanted to get into. When i start bleeding the breaks on ABS systems I’ll likely lean towards that route.
Im intrigued by the Speed Bleeder design mentioned in post 12. Very cost effective and easy to install. Anyone have experience with them?
I installed speed bleeders on all 4 calipers. They were the sweetest thing. I still had ppl helping me, but it made the whole process that much easier. They really should be how all bleeder screws are made. I did struggle a bit to get vice grips to hold the proportioning valve open for me. Ended up just holding it open while someone else pressed the brakes. They used to make a fancy clip for this purpose. But they literally don’t exist anymore(dang shame).... Dorman 12701 fit all 4 calipers on my 77 f150 in case anyone else is interested. It allowed me to enjoy the job a bit more, and im pretty sure its going to lead to me flushing my brakes more often.
gravity bleed. works but check on it every so often.
I wont say it doesnt. But brake fluid draws moisture. The fact that i’d need to leave my bleeder screw open long enough for gravity to take effect is a passive way of getting a job done. No disrespect to any gravity bleed crowds.
The only way I've ever done it and will ever do it is with a helper.
My helper sits in the truck and gets the easy job.
I crack open the bleeder as I shout out commands (up or down to indicate pedal travel). I have always had good results using this method and can usually get a really good amount of pressure built up in the system in addition to no air bubbles.
I've never had good luck with any other method.
I concur here as well. No other method of trying to do it faster, or solo has worked for me. I 100% want someone there to assist because you seem to get a better bleed vs trying to do it all yourself with a one man unit, or a vacuum bleeder.
when you open the bottle of brake fluid it can absorb moisture just as likely, or pour it from bottle to master to top it off. its not like your leaving it open for days.
Russell has a number of products in a category they call "Speed Bleeder" that might be worthy of a look/see. I have no experience with it but it looked interesting. Here is a Summit search that shows most of these options.
Sorry to Necropost here, but just came across this discussion. Recently rebuilt the brakes on my 70 (master cylinder, lines, and wheel cylinders), so I was starting over completely. Had my son named Russell as my helper, doing the bleeding the old fashioned way. We were at it for quite a while, and still no pedal, so I finally just decided to punt that day. Ordered Russell Speed Bleeders for all four corners and swapped them out. I then had my son Russell pump the pedal 7-8 times between my topping off the MC. In just a few minutes, I was able to just WATCH the fluid until no more air bubbles, and visited all four corners. We quickly had excellent pedal feel.
For me, the Russell Speed Bleeders were worth the ~$21 they cost. I think the biggest part of the problem was probably the cheap bleeders that came with my new wheel cylinders. Must have been sucking in air despite my best efforts.
Speed bleeders work great and their chief attribute may be in the way they help promote marital or familial bliss. Gravity bleed works really well for simple braking systems. It generally takes years for brake fluid to absorb enough moisture to cause trouble, but it's supposed to absorb moisture, if it didn't, the brake fluid would freeze in the winter and/or boil in the summer, neither of which is any good for braking. Fluids were chosen carefully, it isn't some kind of blind spot of the engineers.
@fordrealdrive Good evening,
sorry to revive old thread. I'm trying to bleed my 1982 C700, it has the single circuit HydroVac system. How did you successfully bleed your F600's system? I replaced the master and booster on mine, as well as a few solid and flexible lines, and after 12 quarts of fluid, it still takes 3 pedals until I have any brakes. Any tips from your experience?
I've used the two person "pump up ... hold it ... again ... " method for most of 50+ years, but if changing fluid out, It works about 100% too.
I like the compressor operated vacuum bleeder with a jar on top of the master to let new fluid in as old is pulled out through the caliper / wheel cylinder end. It pulls fast, so stop and check the fill bottle often. The vacuum route depends a lot on a good seal at the bleeder valve. It works OK with just one person as they control vacuum and are opening & shutting bleeder valves while laying on the ground.
I also made and have used a pressure type based on a garden sprayer. If I can get the sprayer leak proof on the master cylinder, it's good enough but it's best with two people ... one monitoring the pressure end ... and another opening and shutting bleeder valves..
On my bikes, the Mighty Vac hand pump worked super for brakes and clutch.
I've also tried speed bleeders and a jar, they worked too.
I have a hose with a spring loaded ball valve but just never had great luck with that though.
Im about to install a new master cylinder on my truck and was wondering about the handy vacuum bleeders that hook to the air compressor. Anyone bleed their breaks using that or a hand pump to pull the air out of each caliper? Curious about the experience and if you were able to get all the air out of the system.
I did mine about 6 months ago.
I bench bled the master cylinder, with a little plastic nipple and hose kit.
I also wanted to flush the lines out completely, so I did get a helper.
Funny thing is, no matter how many times I have done it, I still have to look up which line to flush out first. I never remember if you start with the nearest wheel, or the furthest wheel, from the master cylinder. Im an idiot. Even though I just did it, I cant remember. I should stop smoking pot.
I tried speed bleeders (don't remember the actual brand). They still allowed air to seep back in. Then I bought a set of Earl's Solo-Bleed's. They actually work!
Earl's Hey Mike, When does hunting season end down in the delta. The herd up here is healthy and stout. Saw lots of big bucks this fall.
