Brake bleeding methods
Old Apr 5, 2019 | 02:37 PM
LiveFrom1977f150's Avatar
LiveFrom1977f150
Im about to install a new master cylinder on my truck and was wondering about the handy vacuum bleeders that hook to the air compressor. Anyone bleed their breaks using that or a hand pump to pull the air out of each caliper? Curious about the experience and if you were able to get all the air out of the system.
Old Apr 5, 2019 | 02:44 PM
caravaggio2000's Avatar
caravaggio2000
Hand pump with teflon tape on the bleeder screw threads and grease around the tube.
Old Apr 5, 2019 | 03:20 PM
Aaron-71's Avatar
Aaron-71
The only way I've ever done it and will ever do it is with a helper.
My helper sits in the truck and gets the easy job.
I crack open the bleeder as I shout out commands (up or down to indicate pedal travel). I have always had good results using this method and can usually get a really good amount of pressure built up in the system in addition to no air bubbles.
I've never had good luck with any other method.
Old Apr 5, 2019 | 03:44 PM
HIO Silver's Avatar
HIO Silver
For these trucks, I concur with Aaron above.
Old Apr 5, 2019 | 04:59 PM
LiveFrom1977f150
I was always the helper growing up. lol. I agree that its an absolutely fail proof method . I was just curious how well these vacuum methods have been working out....
this sounds like a solid method. I figured hand pump was probably the better of the two.
Old Apr 5, 2019 | 08:50 PM
RalphXL's Avatar
RalphXL
I've never had trouble with a hose on the breather screw leading to a soda bottle half full of brake fluid.
Jess
Old Apr 5, 2019 | 10:10 PM
niko20's Avatar
niko20
I used the bottle method which allows you to bleed the brakes on your own. Look up ChrisFix on youtube on brake flushing he shows the bottle method. Works excellent.
Old Apr 6, 2019 | 04:44 AM
ranger140892's Avatar
ranger140892
Grumpy goat
Yep, my preferred method also. It works. And I don't have to wonder if a helper is depressing brake pedal too little, or so hard that he's bending the pushrod. I can also gravity bleed since I got rid of the old factory proportioning valve.
Old Apr 6, 2019 | 09:33 AM
LiveFrom1977f150
Awesome. I think i might just give that one person method a shot. I like the simplicity of it. I appreciate the replies, this forum has been incredibly informative since i bought the truck.
Old Apr 6, 2019 | 09:36 AM
Ozzie H.'s Avatar
Ozzie H.
Since I generally don't have a helper, I'll put a clear tubing on the bleeder and put it into a container and use the gravity method, assuming it will flow. It's often a bit slow, but with patience it will get the job done.
Old Apr 6, 2019 | 10:27 AM
biasvoltage's Avatar
biasvoltage
Haven't used it yet on the dent, but I've had a Motive pressure bleeder for about 5 years and used it on my 94 F250 as well as a bunch of cars. It works really well.
Old Apr 6, 2019 | 10:54 AM
flowney's Avatar
flowney
Russell has a number of products in a category they call "Speed Bleeder" that might be worthy of a look/see. I have no experience with it but it looked interesting. Here is a Summit search that shows most of these options.
Old Apr 6, 2019 | 11:38 AM
FuzzFace2's Avatar
FuzzFace2
If you bench bleed the master before install there is no need to bleed the system.
Yes on the vacuum bleeder, a Snap-On unit. Not 100% good after 1 qt of fluid pulled thru but gave me a peddle so could stop the truck when moving in & out of garage. Once I got a helper the 2 person way got the rest of the air out.
I should also let you know the system was completely drained, new calipers & wheel cly. and lines drained as was the master.
I think the only way a 1 person can bleed the system good is with a pressure bleed system. I have also tried the drip way over time (24 hr) and it also gave me a pedal but not good enough to drive with.
Dave ----
Old Apr 6, 2019 | 11:40 AM
fordrealdrive's Avatar
fordrealdrive
Deleted....
Old Apr 6, 2019 | 11:57 AM
FuzzFace2's Avatar
FuzzFace2
I have all the parts to make a pressure bleeder other then the master lid.
Well I have the rubber for the gasket and think I have the metal just needed to come up with chain & bolts.
That was 6 or 7 years ago now and all still in a box on the shelf.
Dave ----
