Blue tooth/google maps
Old Apr 5, 2019 | 12:46 PM
Gary's 150's Avatar
Gary's 150
Why can I not hear the voice driving commands for google maps when my i phone XS blue tooth is on. It does not come through the radio speakers, nor the phone itself. If I disable the blue tooth, the voice commands come through the phone. I tried turning up the volume control on the radio when the voice commands should have been speaking ( same as I did to turn the volume up on the navigation system). I tried with and without the USB cable connected. It's a 2016 F 150 with the latest version SYN 3 with navigation software update that enables you to access Waze navigation and Alexa skills on in car display.
Thanks
Gary
Old Apr 5, 2019 | 12:53 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I had the same problem, but with an aftermarket Bluetooth radio. There was a setting in Google Maps that asks if you want directions to be sent over Bluetooth. Mine was turned off, I'll bet yours is, too.
Old Apr 5, 2019 | 01:15 PM
Gary's 150's Avatar
Gary's 150
I could not find what you stated in your reply on my phone, but I have "Play Voice Over Bluetooth" enabled. Thanks Mark for your quick reply.
Gary
Old Apr 5, 2019 | 01:45 PM
ford390gashog's Avatar
ford390gashog
Do you have the prompts volume turned all the way down?
Old Apr 5, 2019 | 01:58 PM
Gary's 150's Avatar
Gary's 150
Not sure what you mean by prompts volume. All the volume controls in the google maps settings are turned to loud. Thank you for your reply
Gary
Old Apr 5, 2019 | 03:02 PM
GlueGuy's Avatar
GlueGuy
I've read in a couple of forums that if you go into the bluetooth settings for SYNC that if you turn off media audio, but leave on phone calls it will work.
Of course, if you want to play a podcast or music, that seems like it would not work.
Old Apr 5, 2019 | 07:57 PM
Gary's 150's Avatar
Gary's 150
I could not find "Media Audio" or "phone calls" in the blue tooth settings, only what devices that are listed. Thanks for your input.
Gary
Old Apr 6, 2019 | 04:36 AM
GABAR's Avatar
GABAR
Thanks
Gary
Have you had the APIM checked because Bluetooth problems are a known issue with them.
With that being said and I’m not sure if you care but running navigation via Bluetooth will quickly drain the battery in your cell phone. I also have an iPhone XS Max and everything works so much better via Apple CarPlay and USB.
I’m not sure if you’ve done this but when you have Google Maps on the actual SYNC 3 screen, tap on the screen and in the top right hand corner, hit the settings button and after you hit it, the screen will bring up ways to change or adjust things on Google Maps and one of these adjustments is an actual volume button.
I hope this helps you out.
Old Apr 6, 2019 | 04:38 AM
oldakerw's Avatar
oldakerw
For my case, I have a Samsung S9 which I mate to my F150 via Android Autoemploying both Bluetooth and a USB cable. It is my understanding that the same procedure is employed via I Phone and Apple Car Play.
Old Apr 6, 2019 | 07:16 AM
Gary's 150's Avatar
Gary's 150
Thank you for your reply, I do not have car play. After some more searching, I found in google maps a HFP button that was not turned on. Enabling that I now have sound.
Gary
Old Apr 6, 2019 | 08:09 AM
IndyDog's Avatar
IndyDog
Gary
I'm sorry, HFP?
Old Apr 6, 2019 | 08:49 AM
GlueGuy's Avatar
GlueGuy
Originally Posted by IndyDog
I'm sorry, HFP?
Yeah. That threw me too. I had to go to the google to figure it out.
HFP = Hands Free Profile
Old Apr 6, 2019 | 09:16 AM
GABAR's Avatar
GABAR
Gary
Glad to hear that you figured it out.
If your vehicle has the eight inch screen, the only thing that you need to do to enable Apple CarPlay is to swap out the USB hub for the one that’s CarPlay compatible. It’s a less than $50.00 dollar part and it can be installed by you in under ten minutes.
In closing, you have CarPlay because it’s built into the iPhone.
Old Apr 7, 2019 | 08:18 AM
Brown Dog ADV's Avatar
Brown Dog ADV
Question USB Hub?
My wife would love to have the Apple CarPlay in her 2016 F150 Lariat with the 8" screen. Is that something which could be accomplished with the new USB Hub..? I know she has the CarPlay on her phone.
If so, could you point me in the direct of where I could find the part needed and some explanation on the installation? Thanks!
Old Apr 7, 2019 | 08:42 AM
GABAR's Avatar
GABAR
Sure.....Just go on Ebay or Amazon and type in Ford part# HC3Z-19A387-B
The prices are all over the place but one of the more popular places with free shipping is Fairway Ford out of Ohio and they also have an Ebay storefront.
To avoid cosmetic damage during installation, which takes less than ten minutes, make sure you have a plastic or nylon pry/trim removal tool. Also, there are several videos on YouTube showing the removal and installation....very simple and easy.
I hope this info helps you out.
Have a great day.
