Electric fan controller
Old Apr 3, 2019 | 09:45 PM
TXTrailerdaddy's Avatar
TXTrailerdaddy
So I put in a dual speed electric fan from a Taurus. Powerful fan. I had picked up the relay pack from a Volvo, but decided to go with a dakota digital controller since I have the VHX guages already and it works well with them. My question is, what does everyone have their on off temps set to and does anyone have a speed shut off switch or what do they set their dakota to? I set mine at low on at 190 off at 185. High on at 200 off at 195. I have it set to shut off at 45mph but I was thinking it probably could shut off slower but not real sure. Anyone have any input on this? I've got a big champion aluminum radiator 3 core. with the correct 400 thermostat.
Old Apr 3, 2019 | 11:02 PM
F-250 restorer's Avatar
F-250 restorer
You should set your turn on for low at 5-10 degrees above your thermostat temp. That way you can cruise, when loads of air is rushing through the radiator, on the freeway or highway, without the fan turning on. Set the turn off 10 degrees in the other direction.
Old Apr 3, 2019 | 11:30 PM
TXTrailerdaddy
I can't recall if the thermostat was 180 or 195 that tim sells.. I think it's 180 that's why I did the 190 turn on.
Old Apr 5, 2019 | 09:01 PM
RalphXL's Avatar
RalphXL
400 degree thermostat?
Jess
Old Apr 5, 2019 | 09:58 PM
niko20's Avatar
niko20
Seems most electric fans in cars these days trigger ON around 195ish
Old Apr 6, 2019 | 10:23 AM
TXTrailerdaddy
Jess
thermostat for a Ford 351M/400
Duramaxfanatic1
Jan 31, 2011 09:01 PM
Thoth88
1983 - 2012 Ranger & B-Series
Feb 28, 2007 09:48 AM
workingdog
Aug 11, 2006 09:28 AM
btacarlton
Mar 29, 2006 09:15 PM
Ratsmoker
15
Mar 3, 2003 09:22 PM
