installed battery backwards
Old Feb 21, 2016 | 02:15 PM
Vernon Myers's Avatar
Vernon Myers
After realizing what I had done I quickly corrected the polarities. Since then I've replaced two batteries and two alternators in less than a week span. I noticed that the head lights appeared dim when I had It running last. So purchased a new voltage regulator. Now have a new battery and alternator plus the voltage regulator but I'm leery about installing them. What could be causing these failures?
Old Feb 21, 2016 | 04:31 PM
maples01's Avatar
maples01
I'd check the wire grounding the battery and the engine to frame ground, if old, just replace them all, you need a battery ground to engine, then from the engine to the frame, 4 gauge.
Old Feb 21, 2016 | 05:14 PM
Vernon Myers
The ground wire is brand new , but I'll check for proper connection. Thx!
Old Feb 21, 2016 | 05:28 PM
maples01's Avatar
maples01
Remember, there are 2, most only focus on battery to engine, if the frame ground is not solid, it will cause issues, and someone suggested a good ground on the external regulator.
MNchadwick
Dec 4, 2018 09:24 PM
Mad tiki
15
Dec 14, 2015 10:08 AM
1NiceHarley
Mar 23, 2015 04:12 PM
jimbo81587
Electrical Systems/Wiring
Nov 18, 2004 02:32 PM
Cruiseomatic
Nov 7, 2004 06:01 AM
