Front or rear shocks first?
Old Apr 3, 2019 | 12:46 PM
Pitguy3's Avatar
Pitguy3
FIRST POST!
Hi All, I recently bought a 17- F250SD 4WD FX4 and am wanting to replace the crappy stock shocks. I experienced the death wobble and immediately took it to the dealership to have the TSB18-2268 work done on it. They replaced the steering stabilizer with the "upgraded" one (P/N HC3Z-3E651-F). I have been reading these forums for a while and had a question. My truck is STOCK and I tow a 32ft TT at least once a month for about 100+/- miles at a time. I am replacing the shocks, but a pair at a time.
Question.. Would you replace the front first or the rear? Thanks in advance!!
Old Apr 3, 2019 | 01:04 PM
seville009's Avatar
seville009
I always replace all four at the same time.
If I had to replace only one pair, I’d start with the front due to the steering (this assumes all four old shocks are identical in age and wear)
Old Apr 3, 2019 | 01:08 PM
Pitguy3's Avatar
Pitguy3
All four are the stock "Rancho". The truck only has 16k miles on it, but I am about to start doing my own mods to it. I will do the other 2 soon after, but have only received "permission" to do 2 for now.. LOL!!
Old Apr 3, 2019 | 01:20 PM
Tricon's Avatar
Tricon
Just save up until you have enough to do all 4. Having drastically different damping rates front and rear is going to be weird.
Old Apr 3, 2019 | 01:24 PM
seville009's Avatar
seville009
good point. Makes sense too later on when the new ones will have to be replaced as they’ll be the same age and have the same wear. Plus, if you do only two now, they may not make the same shock anymore when you decide to do the other two
Old Apr 3, 2019 | 02:06 PM
Pitguy3's Avatar
Pitguy3
True... Or just go ahead and order the set and ask for forgiveness instead of permission... Thanks Guys!
Old Apr 3, 2019 | 02:29 PM
RIPbiker13's Avatar
RIPbiker13
You can't put a price on safety! Show her this thread. You're protecting your family and your investment, not to mention everyone on the road. Sounds like you're driving a death trap and need shocks, tires, a moderate lift to make the truck sit higher for added protection from other trucks in the event of an accident.
YOU'RE PLAYING WITH FIRE!
Seriously though, all four at the same time if you're upgrading. Just replacing, it wouldn't matter much.
Old Apr 3, 2019 | 02:46 PM
Pitguy3's Avatar
Pitguy3
It's all stock, no lift, and if it's a death trap, then there are THOUSANDS of them on the road! LOL!!
Old Apr 3, 2019 | 02:50 PM
wicked 2018's Avatar
wicked 2018
get all 4 and say it was buy the fronts, get the rear free ;-)
Old Apr 3, 2019 | 03:14 PM
xxxsherpa's Avatar
xxxsherpa
How long are we talking about between purchase, days, weeks or months? If its a reasonably short time get the fronts first.
Old Apr 3, 2019 | 03:16 PM
Pitguy3's Avatar
Pitguy3
Probably 2-3 weeks... Looking now for the best deal on all 4.
Old Apr 3, 2019 | 03:23 PM
xxxsherpa's Avatar
xxxsherpa
If you can only afford two now (I understand) then by all means order them, you will be fine in that time frame.
Old Apr 3, 2019 | 03:46 PM
tony m 6.7's Avatar
tony m 6.7
All 4 at once, but if you must do 2 at a time, front first.
Old Apr 3, 2019 | 03:57 PM
Pitguy3's Avatar
Pitguy3
The correct part numbers for the 9000XL's are RS999042 (Front) and RS999047A (Rear) correct?
STOCK (NO LIFT) F250 SD Crew Cab Gasser 4WD FX4
Old Apr 3, 2019 | 05:32 PM
wrvond's Avatar
wrvond
If you are buying the Rancho 9000's you need to buy all four at the same time in order to get the rebate. If you buy two, you'll get a partial rebate, but no rebate at all on the second pair purchased.
KC8QVO
6.7L Power Stroke Diesel
151
Jul 25, 2012 04:45 PM
Smoke2008
Jul 27, 2011 03:17 PM
Gwilkrrs
6.4L Power Stroke Diesel
Dec 12, 2010 07:15 PM
foul1
Feb 11, 2010 07:39 PM
mgauger
Mar 11, 2004 12:00 PM
