Flareside Tail Lights
Old Apr 3, 2019 | 10:47 PM
Rusty_S's Avatar
Rusty_S
Originally Posted by Thiessen90
https://www.grote.com/family/torsion...stop-tail-turn
FuzzFace2 I was able to track down your old post and these are the ones you posted that include the side marker. Thanks.
Wonder if one could knock the studs out and reposition them to the correct position and add a third one to maintain oem look.
I might attempt that if I cant source any NOS ones. mine I had to glue the reflector lenses back in on the driverside as it started to get loose and was afraid of it falling off.
Old Apr 4, 2019 | 02:33 AM
Rembrant's Avatar
Rembrant
They're a better match! Nice find.
Old Apr 4, 2019 | 02:36 AM
Rembrant's Avatar
Rembrant
Originally Posted by reamer
So now I'M and Fanatic?
YES!!! lol.
Old Apr 4, 2019 | 09:53 AM
FuzzFace2's Avatar
FuzzFace2
If you go to their site and look up tail lights there is a 3 stud light with a different plug on it.
Dave - - - -
Old Apr 4, 2019 | 12:08 PM
Rusty_S's Avatar
Rusty_S
Dave - - - -
Is that the only difference the plug? If that's the case and its a straight bolt in guess I will have to do some digging after work and order a set. I have no problem snipping the new harness and connecting it to the old connector.
Old Apr 4, 2019 | 04:16 PM
FuzzFace2's Avatar
FuzzFace2
I don't know because at the time I found them I did not have any factory lights or brackets to measure from.
Here is the ones I found last night http://www.grote.com/family/chevrole...il-turn-lights
There is a left & right because of the side marker lights. see if this works and can see what the spec is.
Dave ----
MavSprint
39
Apr 12, 2013 08:11 PM
Spool&Go
57
Sep 16, 2010 08:54 AM
nolan62
May 29, 2010 08:10 AM
superdutymj
Appearance & Dress-Up
May 10, 2008 04:43 PM
