Manual trans guys--help needed.
Old Apr 2, 2019 | 11:29 AM
F-250 restorer's Avatar
F-250 restorer
I have a used zf5. I split the case and installed new p.shaft bearings. I had the flywheel resurfaced and a new Ram clutch, slave cylinder, new pilot shaft bearing. When I start it there is a growl in the bellhousing with the trans in neutral. The growl vanishes when I push the clutch. I had a bear of a time installing the trans, and am thinking now that the growl is either a damaged p.shaft bushing/bearing that sits in the crank, or I messed up when I installed the bearings on the p.shaft in the trans.
How do know where the sound is coming from?
Old Apr 5, 2019 | 09:41 AM
TCR's Avatar
TCR
I’m not really a transmission expert, however I think it might be your clutch. It could possibly use a little adjusting at the fork. I had to lengthen mine (the bolt on the fork) to push it farther out so the clutch would disengage sooner
Old Apr 5, 2019 | 10:06 AM
meangreen92's Avatar
meangreen92
It might be your throwout bearing.
Did you try spinning the input shaft before you shoved it up into the truck?
GravyCrockett
Feb 8, 2018 01:14 PM
peter_x
Aug 14, 2012 01:50 PM
83capril
Aug 16, 2010 02:16 PM
weswes01
Oct 15, 2007 10:28 PM
Somany Myles
May 14, 2003 08:45 PM
