Intake plenums
Old Apr 11, 2019 | 09:48 PM
Hit Man X's Avatar
Hit Man X
Yesssss. S300 wheel. Must get one!
HPOP first.
Old Apr 12, 2019 | 08:12 AM
TJLongworth's Avatar
TJLongworth
Alright the plenums are in for good, Im so glad that part of the project is over. Hopefully the rtv filled all the gaps.
Attached are some photos of the trouble spots, along with an overall photo. With any luck tonight it will be all buttoned up.
You can see where I notched the plenum with a 3/4'' endmill, unfortunately I didnt take a picture of the rear fitting mod. for that I filed the hole square and fit and refit the part wile filing the edge. the goal was to remove the least material as possible
Old Apr 12, 2019 | 08:46 AM
knottyrope's Avatar
knottyrope
Thanks for those pics!!!
i can see that notch enough with the RTV showing to figure it out
Old Apr 12, 2019 | 09:24 AM
TJLongworth
yeah the biggest pain is the drivers side since the brass fitting clears, but the hydraulic line for the fuel does not. A taller brass fitting would solve the problem
Old Apr 12, 2019 | 08:17 PM
pilgrimbizket's Avatar
pilgrimbizket
Rtv looks like a good seal and looks clean too. Nice work. Are you going to run the reducer boots to the E99 spyder?
ronjon95
37
Apr 13, 2019 12:23 PM
z31freakify
Jan 21, 2016 10:54 PM
nateairman
27
Jan 25, 2015 09:56 PM
JT250
Feb 28, 2012 04:10 AM
74baja
Jan 17, 2010 06:52 PM
