Trailer TPMS sensors
Old Mar 31, 2019 | 12:47 PM
kab449's Avatar
kab449
I pulled my fifth wheel for the first time after winter storage. The trailer pressure readings showed in my truck but then blanked out. Some would come back but go away. I got a sensor error message. They are about 3 years old now and I am wondering if they have batteries in them that need changed occasionally? The truck tire pressure readings were perfect.
Old Mar 31, 2019 | 08:06 PM
HRTKD's Avatar
HRTKD
Most tire pressure sensors are non-serviceable. The normal service life is seven to ten years. One a trailer I would expect them to live until the upper end of that range due to usage. I don't know for sure that the trailer sensors are non-serviceable but I would be very surprised to find that you could change the batteries in them.
Check the cable connection. I think it's a 12 pin plug. Another thought is to go through a relearn of the sensors.
Old Apr 1, 2019 | 01:10 PM
kab449's Avatar
kab449
Thanks I'll check the connection and have my local garage use their tool to wake them up.
Old Apr 1, 2019 | 01:30 PM
HRTKD's Avatar
HRTKD
Another forum member reported that they couldn't figure out how to get the truck system for the trailer sensors to go back into the relearn mode. It was relatively easy the first time, but I haven't tried to do it a second time.
Kaadk
Aug 27, 2019 08:00 AM
guessrow
2009 - 2014 F150
Jan 6, 2019 08:08 PM
CASAJOE
6.7L Power Stroke Diesel
Apr 2, 2017 11:53 AM
Logan1080
Nov 11, 2016 12:32 AM
Tallboy2011
Feb 3, 2014 08:06 PM
