Need replacement shocks for rig with 6" lift
Last year I bought a 2007 F150 for my son. The truck has what I believe to be a 6" ProComp Lift. The truck needs new rear shocks and I have no idea what size replacements I should be looking at. Although it's likely a 6" lift (I'm measuring the front lift brackets), the rear suspension only seems to have 2.5-3" blocks. I'm guessing that may be normal for F150 lifts since the front ends had a rake from the factory.
Can anyone steer me in the right direction as to what shocks I should order? The body of the current rear shocks are 17" and the shocks are 25.75" end to end while the truck is sitting on the suspension.
https://www.truckspring.com/products...__TC61301.aspx
call them and verify what you are doing before order.
