Help replacing water pump
Old Mar 30, 2019 | 02:22 PM
Donna McAlister's Avatar
Donna McAlister
We are trying to replace the water pump on a 1986 F250 6.9 diesel. Trying to take off the fan and the fan clutch is free spinning from the bolt and pulley keeps spinning. Also do you have to have the pulley pressed on to the water pump or is it just bolted on.
Old Mar 30, 2019 | 07:54 PM
Franklin2's Avatar
Franklin2
You can go to autozone or possibly one of the other stores has them also, and rent the special tools need to get it off. The fan unscrews off the pump. You will need the special large wrench and the other tool that holds the pulley still. You will probably have to smack the wrench with a deadblow or something to break it loose. This is hard to get in your head sometimes, probably less of a problem with someone that is not a mechanic, but THE THREADS ARE LEFT HAND THREADS. So to take it off you have to smack it to the drivers side to get it loose.
The the pulley just unbolts like any other.
I spent 20 minutes once trying to get my clutch fan started back on after working on my truck, and I finally realized I was trying to turn it to the driver's side like it had regular threads. Turned it backwards and it went right on, what a dummy I was.
shawnlgerber
Oct 2, 2018 05:50 AM
Tim Shultz
Jun 12, 2008 06:52 PM
RhinoScores
1983 - 2012 Ranger & B-Series
Dec 15, 2006 06:09 AM
1poorboy69
Sep 18, 2005 12:54 PM
Anchor-D-Ranch
Jun 22, 2004 02:50 PM
