I.D. A Wire 1984 F150 4.9
Maybe I'm not bright enough to read them properly or I'm having a vision problem, but the electrical schematics that I have don't seem to show where a big, black wire in my engine bay goes.
Please see attached photo for reference.
There's a broken wire that's poking out of the main wiring harness on the passenger side of my truck, and I don't have a clue where it goes.
Can anyone with a 1984 F150 4.9 take a look at their wires in this area and let me know where this one hooks up to? I would really appreciate that.
I suspect it has some importance as the truck is now running rich and the code reader will not work when plugged into the test connection.
Thanks in advance!
The wire in question is circled in red.
Thanks in advance!
Well, I do appreciate your help. Sometimes the most simple things are overlooked - I've done that.
I was hoping that someone with a stocker could take a look at his harness and ID that wire.
I have been tempted to disconnect all of the feedback carb & emission stuff, but it's such a happy runner.
Thanks again,
Dan
Thanks again,
Dan
Keep it stock as long as it runs well. The Ford engineers knew what they were doing. With the feedback system, the 4.9L engine can return good performance and surprisingly good gas mileage, when driven conservatively.
Great thought!
It looks like that wire does go into the cab.
I did pull the connector to the computer (under the dash) last night and briefly looked over the wires there. I didn't see a black wire that looked as hefty as that in the connector - initially. I'll look closer tonight.
One thought I had - since it has a plug that can be disconnected, I was wondering if it went to some component?
Thanks,
Dan
Thanks,
Dan
Does that black wire have light green dots on it by chance? It looks like it could be the one described on page 10 of the EVTM here:
Grounds - Gary's Garagemahal (the Bullnose bible)
Connector C101 would connect direct to a battery negative pigtail; haven't found Splice 258 yet.
It must be the ground wire that connects directly to the battery? Connector C101 shown below?
I went back and looked at my own pics...see the thread below, and you can see the exact same wire on the 85 I took apart, but you can't see where it goes...
But I'm thinking it went to the battery or the ALT...
https://www.ford-trucks.com/forums/1...nector-qs.html
