Sponsored by: Real Truck
V10, 6.2
Old Mar 27, 2019 | 11:20 PM
shrtmem's Avatar
shrtmem
V10, 6.2
Hello all,
I have a 2000 Excursion, 2WD, V10. My husband took it hunting during a very rainy weekend and sunk my baby in the mud . I hate to say it but a Dodge saved the Ex from a dip in the lake as it was going downhill backwards. smh,,,,,,,,,,,, My husband has vowed for that to never happen again and is looking for a 4x4. We are looking at a 2015 F350 Super Duty 6.2L V8, 4x4. I have the vin but I can't figure out what axel this truck has. I'm trying to see it's towing capacity. I have a Cougar trailer that weighs @ 7300. And yes, my husband has told me that he is putting a winch on the front and back of the new truck.
Thank you in advance
Old Mar 28, 2019 | 06:11 AM
projectSHO89's Avatar
projectSHO89
The VIN does not include the axle code unless you can look up the as-built configuration. I don't know if the Etis site still works or not.
Otherwise, you have to get to the sticker on the door or door jamb and get the AXLE code off of it or someone has to crawl under the truck and try and read the code off the tags on the axle. Getting the code off the sticker is easiest.
Old Mar 28, 2019 | 07:02 AM
Sir Kayakalot's Avatar
Sir Kayakalot
And for Gods sakes, don’t ever admit on a public forum that a Dodge pulled your truck out of the mud.
Crawl under the truck at the rear and on the back of the rear differential there should be a metal tag that has the axle ratio stamped on it.
Old Mar 28, 2019 | 07:33 AM
SnowPlowDriver's Avatar
SnowPlowDriver
Dont let the axle ratios be a deal breaker. Either will pull a 7300 lb. Trailer.
Desert Don's Avatar
Desert Don
Originally Posted by shrtmem
Hello all,
This truck will have no problem pulling that 7300 lb trailer regardless of the axle ratio. 3.73 or 4.30 are the only two options with the 6.2 gasser and either one wil be fine. Even if the 7300 is the empty weight, what......10,000 GVW? Still just fine!
Old Mar 28, 2019 | 08:11 AM
GlenPxC's Avatar
GlenPxC
I have a f350 6.2 with 3.73 ratio and it pulls our 7500lb camper very well. That's not a very big camper for these trucks. I previously pulled it with an f150 and technically it was within the weight limit, but the super duty does a much better job.
Old Mar 30, 2019 | 11:25 AM
shrtmem's Avatar
shrtmem
So we got the 2015, F350, 6.2. Seems like a really nice truck. My husband is spending day 2 alone with his truck. Guess that is what comes with 43 years of marriage. Anyway, I thought the Ex was huge, this truck makes the Ex look like a commute car. Seems our trailer hitch will not be lining up with the height difference. Do we need a new hitch or is there some kind of adaptor? We still have the Ex but it has to go to dealer. Last week we took it in as the blinkers had stopped working. They had to remove the steering column to fix that and now the windshield wipers are not working. sheesh!
Thank you
Old Mar 30, 2019 | 11:27 AM
shrtmem's Avatar
shrtmem
I know, I know, it hurts real bad to say it, but gotta give props where props are due.
Old Mar 30, 2019 | 11:29 AM
projectSHO89
Unless you're using a WD hitch, drop adapters are readily available.
Old Mar 30, 2019 | 01:09 PM
shrtmem's Avatar
shrtmem
We do have a WDH on the Excursion and the F350. I think my husband said there is a 4 inch difference between the two. The F350 being taller.
Old Mar 31, 2019 | 10:50 PM
GlenPxC's Avatar
GlenPxC
Depending on the tongue weight of your trailer you may not need the WD hitch anymore. I had one from when I pulled our camper with the f150 and when we got the f350 I stopped using the bars as it barely squatted. Still use the anti-sway bar though. All you probably need to do is adjust the height of your hitch ball.
Old Apr 1, 2019 | 10:23 AM
pennsylvaniabo's Avatar
pennsylvaniabo
Are you asking what axle? if so it's a sterling 10.5, if you are asking axle ratio, look at the axle door code. 37,3E, etc
  • 35 - 3.55 non-limited slip
  • 37 - 3.73 non-limited slip
  • 3J - 3.55 limited slip
  • 3L - 3.73 limited slip
  • 41 - 4.10 non-limited slip
  • 43 - 4.30 non-limited slip
  • 48 - 4.88 non-limited slip
  • 4L - 4.30 limited slip
  • 4N - 4.10 limited slip
  • 4W - 4.10 limited slip (ambulance package)
  • 53 - 5.38 non-limited slip
  • 5L - 5.38 limited slip
  • 8L - 4.88 limited slip
Old Apr 1, 2019 | 01:17 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Hello all,
I know this feeling all too well and is exactly why I bought my 4wd 2005 Excursion.
You'll be happy with the 6.2 truck, lots of refinements the Excursion doesn't have. I myself am looking into the new 2020 models with the 10-speed.
Old Apr 1, 2019 | 03:22 PM
redford's Avatar
redford
...and the optional 7.3L gas engine.
Old Apr 1, 2019 | 04:29 PM
Toreador_Diesel
That's actually what I'm looking forward to, I need the power of a diesel just not the price tag or the expensive issues that sometimes come with it.
HydroDog
Aug 8, 2008 01:24 AM
motorhead_83
Modular V10 (6.8l)
Feb 26, 2008 03:33 PM
RaftWW
Jan 2, 2006 11:46 AM
hoffster
Jul 17, 2005 01:13 PM
Marvin882
Jan 22, 2004 05:08 PM
