More 1972 F100 engine
Ditto on carbs. Yes, the Ebok doesn't have the leak issue like a Holley over time. But I'm not a fan of that style carb. They do work.
I've always run just fine with stock brass radiator and stock fan. For a "stock" kind of build it is more then adequate. Unless you live in the desert and need more cooling.
I was basing the Edelbrock on reading around the internet. I don't think it would be a bad decision. If think the 390 is just stock and no special needs, just a driver. Heading over with the 360 trans to see if it will be a little better for rebuild? So far everything looks the same on both transmissions externally.
Yeah, I'm not sure about some of this stuff so research and opinions help a lot. On the transmission, adding a 5th clutch to the 72 360 C6 using parts from what he says now probably was a 65 C6 trans. He said the new seals plus being able to use new fluid will help some of the old problems with C6 transmissions. If anyone is interested? This guy has been doing transmissions his entire working life. Plus affordable!
bulrydr_1
06-10-2005 07:54 PM
KJKozak2
03-31-2004 08:45 AM
