7.3 powerstroke wont start
Old Mar 27, 2019 | 05:04 PM
Scott Dell's Avatar
Scott Dell
Been having an issue with it just driving down the road it shuts off. No warning no lights. Just shuts off.. third time i change cp sensor it started up. Thought i had it. WRONG AGAIN!!. So i changed fuel pump and it started. I pulled it put of the driveway and put it in drive and well had to be pulled back in by my tractor. What ever is doing it it shuts down fuel pump and diognostic doesnt even pick up anything from the pcm. Any help would be gratful. Im tired of its games
Old Mar 28, 2019 | 08:04 AM
Colorado350's Avatar
Colorado350
Welcome to FTE.
Bad batteries or corroded connections can cause all kinds of issues with the truck. Unless the batteries are brand new I would charge them individually and have them individually load tested. Do you have any gauges, fuel pressure would definitely help in this situation? Have you checked your fuses that they are all tight and firmly in place? If you take a flashlight and look underneath your dash at the back of the fuse box do you see any indication of water intrusion? Water will leak into the windshield and cause all kinds of electrical gremlins. Is the truck giving you any kind of codes??
Old Mar 28, 2019 | 09:36 AM
chasteen1156's Avatar
chasteen1156
Check the wire going to the cp sensor. Mine did the same thing and it ended up that wire was shorting against the engine and causing it to die. The short was just above the cp sensor at the front of the engine.
Old Mar 28, 2019 | 10:03 AM
redford's Avatar
redford
FTE Leadership Emeritus
Moved to 7.3L PSD Engine Forum.
thieb
Apr 11, 2018 06:28 PM
Aki_A
38
Jun 10, 2011 03:32 PM
xTraveler
34
Jul 23, 2008 06:59 PM
advdrywall
Nov 13, 2007 08:03 PM
Panther52
Jun 13, 2006 04:46 PM
