VGT %
Old Apr 3, 2019 | 09:44 PM
FL SuperDuty's Avatar
FL SuperDuty
if you have a scanner check EBP or EBP volts. a bad EBP or EBP connector can cause bad VGT commands. a bad electrical connection or failed sensor should throw a CEL.
different tuners work the VGT differently. i know one of my tunes sweeps the vanes from 84%-15% occasionally at idle. i would not assume anything is wrong just by having VGT at 85% at idle. if you are not overboosting (seeing 30 lbs of boost) or underboosting (lots of smoke) i think you are ok.
sometimes the EBP tube gets clogged up. try cleaning it out if you want to go that route. mine was full of soot.
Old Apr 3, 2019 | 10:11 PM
bismic's Avatar
bismic
One of the easiest ways to do a quick (but not comprehensive) test is to compare EBP, MAP, and Baro at KOEO. They should all be within approximately 0.5 psi of each other.
Old Apr 4, 2019 | 11:42 AM
Rod Jr.'s Avatar
Rod Jr.
Thanks for the advice, that will save me some time, looks liked I don't need to clean EBP, my KOEO readings:
BARO 14.4
MAP 14.4
EBP 14.6
Old Oct 30, 2022 | 05:15 PM
jkinghorn6.0's Avatar
jkinghorn6.0
I'm having low to no boost issue. I checked my BARO, MAP, and EBP KOEO
BARO 12.2PSI/2.42v
​​​​​​MAP 12.2PSI/1.04v
EBP 3.3PSI/0.0v
What would be recommended? I installed a new EBP sensor last week. I cleaned the EBP tube while i was replacing my oil cooler and egr cooler over the weekend.
Old Oct 30, 2022 | 05:38 PM
bismic's Avatar
bismic
What are you using to get the readings?
Old Oct 30, 2022 | 05:53 PM
jkinghorn6.0
Im using Forscan. When idling @ 194° the EBP is at 6.6psi and the others only rise .2 to .3 psi
Old Oct 30, 2022 | 06:06 PM
bismic's Avatar
bismic
I assume that is the "EBP_G" PID and not the "EBP_A" PID?
The Baro shouldn't change at anytime - unless you are changing location and altitude.
MAP should only be a few tenths at idle. EBP at 6.6 pisG doesn't sound bad either with a hot engine or at high idle
Old Oct 30, 2022 | 06:21 PM
jkinghorn6.0
Well I have just finished replacing the oil cooler and egr cooler. I was getting p1335 on my egr valve si I swamped it from my other truck thinking it was causing the issue but it didn't change the boost issue. I cleaned the vgt when I had the turbo out and the veins looked good from looking through the exhaust side to the y pipe. I've only had the truck a couple of months
Old Oct 30, 2022 | 06:32 PM
jkinghorn6.0
I used actual for my numbers
Old Oct 30, 2022 | 07:01 PM
bismic's Avatar
bismic
EBP_A is an "absolute" pressure
EBP_G is "gauge" pressure
At least as far as I know!
EBP_A minus EBP_G is ALWAYS supposed to equal the Barometric Pressure.
Old Oct 30, 2022 | 07:20 PM
jkinghorn6.0
My baro is 24.7.
Old Oct 30, 2022 | 07:26 PM
bismic's Avatar
bismic
24.7 what .......
Every number needs "units of measure" with it. Like saying my bank account has 1000 in it. 1000 cents, dollars, etc!
In the post copied from above, you said Baro was 12.2 psiA
BARO 12.2PSI/2.42v
EBP 3.3PSI/0.0v
BTW - 12.2 psi equals 24.8 inches of mercury
  #28
jkinghorn6.0
sorry not 24.7. Dam auto correct. Here is forscan screen shot earlier
Old Oct 30, 2022 | 07:28 PM
  #29
jkinghorn6.0
just now
Old Oct 30, 2022 | 07:31 PM
  #30
bismic's Avatar
bismic
84.5 kiloPascals is the same as 12.2 psia
