Sponsored by: Real Truck
Tongue Weight Help
Old Mar 26, 2019 | 04:34 PM
elucas's Avatar
elucas
Angry Tongue Weight Help
I have a 2016 F250 Crew cab/short bed 6.7L. I want to tow a car trailer that does not allow for a weight-distributing set-up. The trailer, loaded, will be just under 10k lbs and tongue weight of right around 1k lbs. My current hitch won't handle that (2..5", 850lb max tongue weight) so I need to upgrade. My question - and i can't seem to find this - is if I put a very heavy-duty hitch on the truck (looking at a 2700lb capacity hitch), what's the max tongue weight the suspension will handle? The hitch company says 1,400 lbs.
I have the specs from Ford Fleet that show 14k max towing and 1,400 max tongue weight, but that's for a weight-distributing set-up. Help.
Old Mar 26, 2019 | 06:49 PM
Chuck's First Ford's Avatar
Chuck's First Ford
hitch is NOT everything... the truck frame where the hitch mounts.. and forward..... the support hardware.....
why can't you add weight-distributing.... it's simple to add...
Old Mar 26, 2019 | 07:50 PM
elucas's Avatar
elucas
The car trailer is a v-nose - there isn't room in the front to mount the hardware on the trailer frame needed for the bars. Weight-distributing would be ideal and I'd go that route if I could.
Old Mar 26, 2019 | 08:14 PM
elucas's Avatar
elucas
Old Mar 26, 2019 | 11:12 PM
Claluja's Avatar
Claluja
How far are you towing, and how often?
I tow 14K quite a bit with my 2014 F250. I dont have airbags. Without my wdh, I squat a little bit. Wdh makes it much better, but I've towed thousands of miles without it.
Btw, your setup looks like it would have about the same tounge weight as my 14K even though you are lighter, because your set up looks like more weight forward than mine. So thought here is that its doable without wdh, but not ideal. If you're going to be doing this often and long distances, maybe consider airbags if you feel you are squatting too much.
wrvond
All Things Towing
Jan 26, 2017 05:59 AM
RAGaz
All Things Towing
Jul 21, 2009 05:19 PM
97_Ex
May 9, 2007 03:20 PM
dlp
Nov 1, 2004 07:33 AM
bkvanbek
Jul 2, 2004 06:58 AM
