Beautiful Blue 1974 Ford F-250 Highboy Is Pure Perfection
By Brett Foote
Does it really get any better than a nicely optioned Highboy painted in this classic shade of blue?
By Brett Foote
That truck does have great curb appeal and is in fine condition. Beautiful color. It does have some mods and just on a couple personal opinion notes I never quite understood the need to lift a highboy unless mud bogging. To me one of the signature signs of a 73-77 highboy is the in-cab fuel tank. When the stock fuel tank is removed it kinda takes away from the ambiance of owning a highboy.
This truck has also been lifted higher than a stock High Boy, has aftermarket wheels and rear bumper, a steering column from a 1978/79 and a 'gypo' air cleaner.
If you think a Mustang tank located where the spare tire is...is safer than the in-cab tank, you don't know beans about the exploding Pinto gas tank FIASCO!
I've seen other builds where the in-cab tank is moved. Obviously the later trucks had the aft mounted tank.
So which one do you guys prefer? Is it worth it to relocate the tank on a highboy?
I actually liked the modifications on the truck and really like it overall. Except maybe the lift and wheels. If it were mine, I would go steel wheels and poverty caps (even though they were never offered for the front on f250 4x4s). To each their own.
Aside from that its personal preference to do with your truck what you want. Everyone views these things differently and only you can decide if its worth the money and work to relocate it and how it may or may not affect future value better or worse. Most likely the value on highboys will continue to rise. One guy I talked to relocated his because he wanted to use the space to install a big sound system behind seat. An example of personal preference. Admittedly I like to keep things stock in my old vehicles. When I was looking for a highboy, I passed on 3 nice trucks that had the tank relocated and saw a few others that had been relocated so its not uncommon. I didn't really know if it was because of safety or the cab was replaced but I expect more often the latter when rusted cabs are replaced with ones from other than the highboy.
Your arguments that the in-cab tank being better are indeed valid. My truck has both (1974 in cab 17 gallon and 17 gallons or so out back). I use the in-cab tank mostly since the fuel gauge works and the tank doesn't leak at all. The rear tank leaks if over 3/4 full and gauge doesn't work. The safety argument is invalid-- a rear end collision would be highly unlikely to damage that tank, and an accident bad enough to damage the in-cab tank would likely be fatal. I just want the convenience of one large quality tank somewhere under the truck to free up storage space inside the truck, and avoid the filler neck sticking out the side. I like stock, but there are some things that there is no good reason NOT to upgrade-- the headlights being a great example.
Labrec01
09-14-2011 10:09 PM
Countrybumpkin
12-15-2004 02:29 PM
