Overdrive relay
Old 03-25-2019, 12:44 PM
Lawrence Petty's Avatar
Lawrence Petty
Lawrence Petty is offline
Angry Overdrive relay
1955 Ford F100 - switching to 12v. Need wiring info/diagram on 12v OD relay. My old one had 6 wires going to it. Picked up a mid 60's Rambler 12v relay (think its #3167318) with 6 posts. However the posts have stampings on them that do not correlate to the Fords. It has two NO, NC, B, 1 & 2. Has fuse on one side stamped NO & B; one end crossed posts 1 & 2; other end crossed posts NC & NO. Can anyone help me getting this wired in as I already have all the other 12v stuff for the conversion. "Petty3377@msn.com" or text 505-635-4291 ... can send pic
Old 03-26-2019, 07:05 AM
turnrjr's Avatar
turnrjr
turnrjr is offline
There was a post on the HAMB about this. A guy gutted the stock relay enclosure and installed a modern 12 volt cube relay inside the old enclosure. I'm going to do this when my project gets to that point. I saved more details if you need them. Let me know.
Old 03-26-2019, 07:35 AM
seef's Avatar
seef
seef is offline
Hi, sorry to brake in like this, but any info will be apprciated. I'm rebuilding my 55 truck which has an overdrive but i don't know if the relay is still functioning or not, same goes for governor en solenoid. Your tip about rebuilding the relay with a simple modern cude relay is a great one. Save's me a bunch of $$$
So if you have a wiring diagram? That would be appriciated...
Old 03-26-2019, 11:07 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Does the cube-relay conversion momentarily kill power to the points like the original? I can't think how it would.
Old 03-26-2019, 12:39 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
B6AZ-7A651-A .. 12V Overdrive Relay / Obsolete
1956/58 F100 // 1956/58 Ford Passenger Cars & Thunderbird. Ditto 1959 before production date 6/1/1959.
HILLTOP CLASSICS in China Grove NC has 2 = 760-746-0400.
Studebaker used a similar 12V relay.
Old 03-27-2019, 08:30 AM
turnrjr's Avatar
turnrjr
turnrjr is offline
Here is a good post/link on the subject from the HAMB: https://www.jalopyjournal.com/forum/.../#post-7985405
Also these are some things I saved for my use when I get to that point in my restoration.
Ross, admittedly I don't have an understanding of electrical theory beyond the basics. It was my understanding that one of the poles of the kick down switch under the gas petal initiates the brief interruption of ignition. Maybe I'm wrong??
Old 03-27-2019, 09:27 AM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
The ignition switch can be quickly switched off and on and the result will be the same as hitting the "kickdown" switch. The OD will disengage. Another interesting thing about these units, the governor can be bypassed and replaced with an "on - off" toggle switch which will give you six speeds forward by allowing the OD to be engaged in second and first gear. After fifty plus years I forget exactly what the problem is but the reverse interlock is affected and I believe you must pull the OD cable to get the unit out of OD before the vehicle will go into reverse. Or maybe the vehicle is prevented from going backwards. Use caution.
And of course, we all know the OD gives clutchless shifting once the vehicle is moving. .
IMO, the OD was the greatest feature one could have on these old vehicles.
Old 03-27-2019, 09:32 AM
raytasch's Avatar
raytasch
Believe Nothing
Duplicate post...…...Deleted
Old 03-28-2019, 03:28 AM
seef's Avatar
seef
seef is offline
THANKS! for the electrical scheme on the overdrive!
Old 03-28-2019, 03:57 AM
seef's Avatar
seef
seef is offline
Thanks for your info, would you, by any change, know how to test if the governor still functions?
Old 03-28-2019, 07:25 AM
Jersey devil's Avatar
Jersey devil
Jersey devil is offline
Put governor in a vise, attach electric drill to shaft. Attach one lead of volt/ohm meter to governor lead and the other lead to the case of governor. Have meter set to test for continuity. As the spinning governor gets up to speed the meter should show full deflection or continuity. At that point the governor is acting as if if has reached it’s about 27 MPH cut in speed.
Hope me this helps,
tom
The following users liked this post:
Old 03-28-2019, 03:04 PM
seef's Avatar
seef
seef is offline
GREAT! Thanks for enlightening me, will give this a shot!
99FORD EXPY.
01-17-2013 06:50 AM
V10man
Electrical Systems/Wiring
12-01-2012 11:27 AM
Shattered
09-21-2012 11:04 AM
Conanski
06-20-2007 10:57 AM
movieprops
18
12-15-2006 10:02 PM
Quick Reply: Overdrive relay
