Long crank time.
Old Mar 25, 2019 | 12:16 PM
Bitty's Avatar
Bitty
Long crank time.
I started to take my truck apart to do the egr delete. Just before I removed the turbo I realized it already had a egr delete. I put the truck back together and now when cold it takes a long time to start, like 3-5 min of cranking time, and it kills the batteries. I think it could have something to do with oil or fuel pressure??? I can't find any loose connections.
it's a 2004 F350 6.0
Old Mar 26, 2019 | 05:46 PM
Mich6.0's Avatar
Mich6.0
after it starts does start right up after you shut it off? I have had a problem and thought it was stand pipes and dummy plugs , so after doing both still had a problem so now nipple seals and injector seals next.
Old Mar 26, 2019 | 07:02 PM
Mich6.0's Avatar
Mich6.0
cranking that long will draw your batteries down and burn out your FICM, be careful if it don't start in 15- 20 seconds stop and try again , connect a high power charger to it and try again low voltage is a FICM killer.
Old Mar 27, 2019 | 06:50 PM
Bitty's Avatar
Bitty
After it started it ran good. Now it starts up normally. Thanks for the help.
hink10
Feb 11, 2020 05:41 AM
pebell
Feb 25, 2018 07:15 PM
Norton72
Nov 8, 2016 08:57 PM
HowieE
May 30, 2015 06:03 AM
mackl1
May 23, 2010 09:18 PM
