View Poll Results: What Oil are you using
Motorcraft Full Synthetic Diesel Motor Oil (5W-40)
11.43%
Motorcraft Super Duty Diesel Motor Oil (10W-30)
17.14%
Liqui Moly Special Tec AA Diesel
0%
Phillips 66 Kendall SUPER-D XA
0%
Shell Rotella T6 Full Synthetic
26
37.14%
Shell Rotella T4 Triple Protection
4.29%
Royal Purple Duralec Super
0%
Schaeffer 711 or 722 SynShield OTR Plus
0%
Other
20
28.57%
Not sure, take truck to local shop / quick lube shop
1.43%
Voters: 70. You may not vote on this poll
Old Mar 25, 2019 | 10:42 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
There is a continuing debate on which is the “best” oil for our 6.7s out there. Thought I would start a little pole on what folks are using. I didn’t add a weight, some of the list above make multiple weights that meets the WSS-M2C171-F1 standard. If a company called their 5W-40 and 10W-30 something different I added the weight. If you are going to change what oil you use based on this pole I recommend you check the approved list to make sure the weight is on it - https://www.fcsdchemicalsandlubrican...ry=Motor%20Oil
I did my best trying to capture what I’ve seen folks using. If I missed what you are using, please post a reply and I’ll update post 1 adding what you use and 1 vote. The pole is limited to 10 choices. If you wish to have your "other" vote remain anonymous please shoot me a PM.
Other:
Valvoline PBE - 5
Delo 400 LE - 1
AMSOil - 1
Schaeffer Supreme 9000 - 1
I didn't include AMSOil on the original list as I couldn't find it on the Ford WSS-M2C171-F1 standard list. I know AMSOil people are pretty passionate about it. Same with Schaeffer Supreme 9000, didn't see that on the list. That's what I'm using but it's the 2017 pre Ford WSS-M2C171-F1 standard.
Old Mar 25, 2019 | 11:19 AM
Overkill2's Avatar
Overkill2
First vote. Motorcraft 10w30. Probably gonna be some "Other" for PBE, Amsoil, etc.
Old Mar 25, 2019 | 11:34 AM
HRTKD's Avatar
HRTKD
Valvoline PBE seems to be the most popular around the forum. I would bump the also-rans out of there and replace with Valvoline PBE.
Old Mar 25, 2019 | 12:20 PM
Just Strokin's Avatar
Just Strokin
I have used all three in mine. T6, PBE and Motorcraft. 5w40 Synthetic for all. So, really can't answer your poll unless I can vote 3 times.
Old Mar 25, 2019 | 01:10 PM
No.15's Avatar
No.15
Vavoline 5w40 or 15w40
Old Mar 25, 2019 | 01:26 PM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
I've been using the 15W-40 Motorcraft Synthetic Blend. For use when towing in hot climates. Seems to be doing a good job so far!
Old Mar 25, 2019 | 02:01 PM
Deuce40s's Avatar
Deuce40s
Schaeffer Supreme 9000 synthetic. It's not on Ford's list.
Old Mar 25, 2019 | 03:18 PM
Martin6's Avatar
Martin6
Delo 400LE 5w-40 Syn (CJ-4) for now and will switch over to Lubrication Engineers 8854 when I run out of the Delo stuff.
Old Mar 25, 2019 | 03:25 PM
dirthawg's Avatar
dirthawg
I voted other - Vavoline 5w40
Old Mar 25, 2019 | 04:00 PM
Claluja's Avatar
Claluja
Voted other. Currently using Amsoil Signature Series 5w40, although have used many others including two on OP's list.
Old Mar 25, 2019 | 05:42 PM
Just Strokin
Ford doesn't make a synthetic blend for diesel. the 15w40 is dino.
Old Mar 25, 2019 | 06:13 PM
golfmedik's Avatar
golfmedik
The first 30k miles was Motorcraft 10W30 or 15W40. In it now and at least the next 3 changes will be PBE 5W40..
Old Mar 25, 2019 | 06:15 PM
kper05's Avatar
kper05
I ran the Motorcraft diesel 15w-40 for 50,000 miles then have been using Rotella T6 5w-40 since. 107,000 miles.
Old Mar 25, 2019 | 06:34 PM
Boilermaker374's Avatar
Boilermaker374
Valvoline PBE 5W40
Old Mar 25, 2019 | 06:39 PM
eddienelson's Avatar
eddienelson
When would you change your oil? At a certain interval or when the computer told you to?
