View Poll Results: What Oil are you using
Motorcraft Full Synthetic Diesel Motor Oil (5W-40)
11.59%
Motorcraft Super Duty Diesel Motor Oil (10W-30)
17.39%
Liqui Moly Special Tec AA Diesel
0%
Phillips 66 Kendall SUPER-D XA
0%
Shell Rotella T6 Full Synthetic
25
36.23%
Shell Rotella T4 Triple Protection
4.35%
Royal Purple Duralec Super
0%
Schaeffer 711 or 722 SynShield OTR Plus
0%
Other
20
28.99%
Not sure, take truck to local shop / quick lube shop
1.45%
Voters: 69. You may not vote on this poll
Ford doesn't make a synthetic blend for diesel. the 15w40 is dino.
https://www.fcsdchemicalsandlubrican...ry=Motor%20Oil
Don't doubt is good oil but as you know, most service managers are nothing more than ticket writers. Most have no real clue nor mechanic/tech experience no current experience either.
With the Motorcraft, I would change around 5,000 miles. Old habits are hard to break. When I switched to the full synthetic, I follow the IOLM which typically means I'm changing it around 7,200 - 7,600.
Received 6,690 Likes
on
Here's the spec sheet on the 10w-30: https://www.fcsdchemicalsandlubrican...ry=Motor%20Oil
It's not a bad oil by any means. But if you're using your truck hard (severe duty, towing) then it may not be the best oil for your truck.
#29
Sorry guy, but Motorcraft does not have a synthetic blend. If it were a blend, They would say so on the container as they do for the Gasoline oils that are a synthetic blend. If you are paying much over $4.00 quart for Motorcraft 10w30 or 15w40, you are getting the shaft. Wal Mart sells 15w40 for $4.12 a quart at my store. For a few dollars more you can buy Rotella T6 a full synthetic.
Rotella is the only one I am aware off hand that has a synthetic blend - T5. There may be others.
Rotells T1 - single weight dino oil 10w, 20, 30 and 50
Rotella T4 - multi-weight dino oil 10w30 or 15w40
Rotella T5 - multi-weight synthetic blend 10w30 or 15w40
Rotella T6- full synthetic 5w40 or 0w40
Motorcraft
10w30 - https://www.fcsdchemicalsandlubrican...ry=Motor%20Oil
15w40 - https://www.fcsdchemicalsandlubrican...ry=Motor%20Oil
5w40 - fully synthetic - https://www.fcsdchemicalsandlubrican...ry=Motor%20Oil
Rotella
https://rotella.shell.com/en_us/products.html
Motorcraft
Rotella
