Hello,
A friend has a 1994 F250 2x4 that needs the differential oil changed. What is recommended? I will probably pop the cap just to take a look for sludge build up and take a look at the gears.
Thanks,
Jcris
Hello,
Thanks,
Jcris
“pop the cap?”
Out of curiosity... what other way were you going to change the fluid if you didn’t remove the cover? Stick a tube in there and suck out whatever you could with a transfer pump?
