8.8 4.10 gear
8.8 4.10 gear
i have a 2005 f150 with the 4.6 and it’s a 8.8 with 3.55 gears and I found some 4.10 gears for a 8.8 on Craigslist link is down below and was wondering if these could work for my truck.
https://orlando.craigslist.org/pts/d...832436596.html
You could buy used body parts, like the entire front end with fenders, hood, bumpers.....if that truck was only rear ended. I would buy used rearview mirrors, window cranks, maybe even a glove box door. Call me pessimistic. I wouldn't buy a used transmission or a used engine either.
As I drive around town, there are still shops which advertise "USED TIRES". Only reason being that someone is actually buying them. A lot of people are buying used tires. Otherwise, those shops would not be in business. Even though most of us buy into the wisdom of not just buying new tires, but also checking the production code date to be sure that we are not buying old tires which have sat in a warehouse for 10 years.
Picture 4 shows something gritty-looking on the bearing that's facing us, so I'm left wondering how much more grit they've had to deal with. Is it lint, paper particles, dirt, metal shavings, or dandruff? I don't know, but it's probably not good.
Picture 6 shows a nick in one of the teeth at about the 10:30 position. Is that from installation or extraction or chunks of metal floating around in the oil? I don't know but it's probably not good.
That having been said, someone will eventually buy this stuff and probably use it for a while successfully. The question is when and how does it fail and are they willing to accept the outcome?
My advice: If you really want or need that extra ~15% reduction and you aren't intending to use the vehicle on cross-country drives and you're willing to restore these to good working order or willing to repair these if they fail then heck go for it. If not then skip. If you really want that 4.10 with less risk then I found this for $154.99 after ten seconds with Google: https://www.cjponyparts.com/ford-rac...SABEgJ2UPD_BwE
New with warranty. I'm sure there are more deals out there.
Dan92
03-09-2011 11:47 AM
84f150guy
02-01-2005 08:01 AM
