1978 - 1996 Big Bronco
Possible Engine Swap
Old Oct 29, 2003 | 07:03 AM
georgedavila's Avatar
georgedavila
Originally posted by monkei
yeah a 460 is very large for a 351 bellhousing and will substantially weigh down the front end causing its nose to sink and carry the majority of the trucks momentum. and the gas cost will kill. but very few things top a 7.5l bronco (a diesel might)
I've had 429/460s in my '82 Bronco since 1986 without problems. They only weigh 200lbs more than the smallblocks. All you need for the swap is a 351M/400 or 460 C6, Econoline 460 oil pan, motor mounts and remote oil filter mount.
http://www.angelfire.com/realm3/george_d/index.html
Old Oct 29, 2003 | 07:53 AM
DW2455's Avatar
DW2455
Why not just rebuild you 351, there very good motors, with a set of AFR 185 aluminum heads, right cam, and a little tweaking of the fuel inhection you can easily make a reliable, streetable, pump gas 400+ HP. DW
Old Oct 29, 2003 | 12:27 PM
Wakeboarder141's Avatar
Wakeboarder141
What kind of gas mileage differences could I expect going from a 351W to 460? Wouldn't I also need a new engine computer and all the other electronic stuff? Why a C6 over a big block E4OD? Thanks.
Old Oct 29, 2003 | 12:51 PM
georgedavila
I've always used '68-78 carburated engines. Others have swapped in newer engines with management systems and the E04D.
Old Oct 29, 2003 | 06:28 PM
monkei's Avatar
monkei
anyone ever put a 6.9 (420 c.i) diesel in. that would be very intersting. i wonder how much more weight that carries over a SBF.
killert
Dec 4, 2016 04:15 AM
kevintoupin
22
May 9, 2016 07:22 PM
Bigred1971
Jan 30, 2016 08:16 PM
terrister
Large Truck
16
Mar 6, 2014 12:56 PM
Blueoval_boy_64
Jan 22, 2009 05:53 PM
