Straight 6 Ignition Issues
Old Mar 25, 2019 | 07:51 AM
FuzzFace2's Avatar
FuzzFace2
Originally Posted by Kramercd
Only issue I have with spraying for leaks is in my little experience, if the leak is large enough and in the right spot that the rpms are so high and it's running so rich that it won't notice a little bit if carb cleaner. Maybe if you went full flood and got enough in to bog it down? I'm going to make a smoke tester in the very near future and post it here if successful.
That did cross my mind but figured it was worth a try.
If it did not find anything then smoke is the way to go.
Dave - - - -
Old Mar 25, 2019 | 09:27 AM
1986F150six's Avatar
1986F150six
Or, buy a $.69 cigar: https://www.ford-trucks.com/forums/1...expensive.html
Old Mar 25, 2019 | 09:33 AM
Kramercd's Avatar
Kramercd
Originally Posted by 1986F150six
I saw that and lots of different homemade smoke testers. Figured I'd try to make one fairly cheap that will run off the battery of the vehicle being tested. If it works out I will share it here. I figure plenty of people won't want to use a cigar.
Old Mar 25, 2019 | 09:51 AM
1986F150six
Just don't inhale!
Old Mar 27, 2019 | 02:38 PM
Mike Ronfeldt's Avatar
Mike Ronfeldt
Everything is now /functional/! After checking for leaks and getting frustrated enough to pull the carb back off and look at everything again, I found the problem. 100% my fault haha. The throttle position sensor was installed in front of the little retaining plate. Apparently it was just 1/8” or so too close to the cap it sits on and it was binding up and not allowing the throttle to close easily.
Not one one of my finer moments but this has all been a huge learning experience for me. Thank you again for all of the help and input from everyone!
Old Mar 27, 2019 | 02:42 PM
1986F150six
Thanks for reporting your findings as that will help others!
Old Mar 27, 2019 | 04:22 PM
FuzzFace2's Avatar
FuzzFace2
X2
Dave ----
Nseal1996
25
Sep 19, 2014 06:26 AM
makthenif
13
Jan 20, 2014 07:50 PM
SlickBastrd
1997 - 2003 F150
Sep 27, 2011 08:06 PM
Malorkis
Jun 7, 2011 01:44 AM
fattmann
Oct 12, 2007 10:18 PM
