Ignition- do they 'just die'?
Old Oct 11, 2007 | 10:22 PM
fattmann's Avatar
fattmann
1987 E-150 4.9l w C6
Stopped to drop somthing off at my grandmothers house, got back in and it wouldn't crank.
Have voltage everywhere- headlights, dome lights, fuel pump, cigarette lighter.. but when i turn it forward to start it, nothing happens. Absolutely nothing. After the fuel pump relay stops, there's no noise, engine doesn't try at all.
Called my brother for advice, suggested jumping the starter solenoid. Couldn't find pliers big enough in my van so i just pulled the starter cable off the solenoid and touched to the battery- started right up.
Is my ignition dead? Never had to deal with ignition problems, so i'm in the dark. Never had a problem like this before..
Thanks for any info.
Old Oct 11, 2007 | 11:02 PM
Clubwagon's Avatar
Clubwagon
The switch could be bad or the solenoid. Solenoids are cheap and easy to replace.
Steve
'95 Clubwagon XLT
Old Oct 12, 2007 | 04:27 PM
rebocardo's Avatar
rebocardo
If you have a TFI module on the dist. , yes, sometimes they just die.
Old Oct 12, 2007 | 10:18 PM
Club Wagon's Avatar
Club Wagon
Bypassing the starter solenoid does not affect the ignition. If it "started right up" you couldn't be suffering from an ignition that "just die(d)". Listen for the solenoid 'click' or use a test light to see if the solenoid is being energized. Often the high amp contacts inside the solenoid just wear out-it is a common part to replace-especially on a 20 YO.
JoeSwing78
34
Aug 23, 2013 05:53 PM
luthoro
Aug 22, 2012 08:26 PM
andyman7931
Oct 17, 2010 06:41 AM
dnrast
Electrical Systems/Wiring
Oct 4, 2004 06:26 PM
