Factory 8 inch display
Old Mar 22, 2019 | 05:04 PM
Shovelhead 93's Avatar
Shovelhead 93
I got a good deal on a 2017 f150 factory stereo system, can I easily install this into my 2015 with 4 inch display, I have satalite and 911 assist in the 2015. Has anyone done this swap. Thanks for any feedback.
Old Mar 24, 2019 | 05:28 PM
GABAR's Avatar
GABAR
The swap can be done but the odds of everything working properly is almost zero because the “APIM” is not programmed to your VIN#.
Unless something has changed, the APIM, which is attached to the back of the actual display screen, can only be programmed to another VIN by a Ford dealer and the odds of you finding a dealer to do this for you is basically zero because that’s not the infotainment system that came with your truck.
With that being said, you would have been better off spending your money on an aftermarket head unit that has Apple CarPlay and Android Auto built in.
Old Mar 27, 2019 | 07:51 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Go here and ask that questions, i sure it has been done with forscan;
https://www.f150forum.com/f118/forsc...987/index1943/
Old Mar 27, 2019 | 08:15 PM
GlueGuy's Avatar
GlueGuy
Depending on what you want to do, these folks can do an upgrade from 4" to 8", but it's going to cost around $1900.
Old Mar 29, 2019 | 12:19 PM
ford390gashog's Avatar
ford390gashog
The APIM is easily programmed without a dealer. I have done plenty of them. There is some other components missing that you will need to complete the swap.
Old Mar 30, 2019 | 06:57 AM
GABAR's Avatar
GABAR
Very interesting 🤔
Can the APIM now be programmed via FORScan or some other method because I’d be very interested in learning more on how you did it.
Old Apr 1, 2019 | 11:53 AM
ford390gashog
It's very easy to wipe and install new asbuilts on the APIM. I believe livinitup has a good write up on it. You just need access to the motorcraft service content to pull as builts.
Longwalker44
13
Jun 2, 2019 10:29 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Dec 31, 2017 08:55 PM
paulnegus
Oct 25, 2017 02:11 PM
RichardW
Mar 23, 2008 09:07 PM
DetailerDave
Feb 6, 2006 07:53 AM
