S&B CAI kit
Old Mar 21, 2019 | 03:20 PM
HiTechRedneck1's Avatar
HiTechRedneck1
S&B CAI kit
Now that I have the S&B installed for a few days I thought I would share a few observations. First off it's very well engineered and at a reasonable price. Installed easily in about half an hour. The air box is sealed with fresh air from the factory location and a clear cover which can be left off. I would add that i use an SCT Livewire for tunes and monitoring. Here is what is noteworthy - if you want that old time "4 Barrel sound" just leave the cover off, but IAT's will definitely climb upwards of 100 degrees from the underhood air temps. Cover on, trusk is a bit more responsive and IAT's are close to outside air temps. In either case, filtration is definitely better than stock.
Old Mar 22, 2019 | 06:17 AM
Robbgt's Avatar
Robbgt
Glad to hear you're happy with it. Keep in mind, the stock airbox you replaced was a CAI as well.
Marginally - the stock paper filter meets at least 98.5% efficiency standard in coarse dust testing. On S&B's website, they state 99% efficiency.
OEMs do't leave anything on the table these days as far as efficiency from intakes.
Old Mar 23, 2019 | 04:27 PM
johnday's Avatar
johnday
I may be buying an S&B as well. What engine do you have this on? Any change in turbo whine if you've got an Ego?
Old Mar 24, 2019 | 11:21 AM
HiTechRedneck1
5.0. but I also had one on a 15 3.5 Eco - if you just want the sound this is probably not the one you want.
Old Mar 24, 2019 | 11:43 AM
johnday's Avatar
johnday
Sound and looks is all I'm after, any ideas for what I'm looking for?
MC5C
Jul 11, 2012 08:47 PM
Sailor182
Nov 24, 2011 06:23 PM
metalman_ickes
May 3, 2009 01:30 AM
fordscj
Aug 19, 2008 03:50 PM
yamaguy
15
Dec 18, 2006 03:24 PM
